245/40/18 or 245/45/18
Old Oct 1, 2007 | 05:50 PM
jer4251's Avatar
Gong to be buyin some tires and wheels. i've got the option to have 245/40's or 245/45's their an 18x8" wheel. dont know if i want more tire on the side wall or not.
any1 have pics of either or?
Old Oct 2, 2007 | 04:02 PM
96 Z 28's Avatar
You should keep in mind that the correct 18" size is 275/35/18 or 245/40/18 in order to ensure the speedometer reads correctly.
So I suggest the 245/40/18, although I am unsure that will fit on an 8" Wheel, seems awful narrow....
Old Oct 2, 2007 | 04:39 PM
jer4251's Avatar
i went with the 245/40's i know 8" is pretty narrow, but the 16x8" wheels my car came with had 245/50's on it.
ill have the wheels next week
Old Oct 2, 2007 | 05:42 PM
Most tire manufacturers will recommend a wheel width of 8.0" to 9.5" for a 245/50-18 tire.
Old Oct 3, 2007 | 11:16 AM
flexus's Avatar
I always use http://www.1010tires.com/TireSizeCalculator.asp to figure out what's best and if stuff fits. I find it quite useful as it also lets you compare multiple sizes to the original one etc.
Good luck
Old Oct 3, 2007 | 11:20 AM
jer4251's Avatar
245/50zr16's are stock, with a larger wheel it needs a lower profile tire, so the 40 series makes the side wall a little smaller. to make up for the bigger rim.
my girlfriends car has stock 225/50/18's. a 245/50/18 would look silly. way too much rubber
Old Oct 3, 2007 | 03:14 PM
Typo..... Most tire manufacturers will recommend a wheel width of 8.0" to 9.5" for a 245/40-18 tire.
94'_Z28
Wheels and Tires
Oct 24, 2005 07:23 PM
kandied91z
Wheels and Tires
Jun 9, 2005 11:59 PM
tweaked96z28
Nov 20, 2003 12:46 PM
nicksL98
Oct 5, 2003 02:51 PM
Asskikr
Sep 25, 2003 02:38 PM
