Ported throttle body a wasted mod?!
Old Aug 8, 2007 | 11:56 AM
6stringer's Avatar
I had a ported throttle body on a previous vehicle and I remember having great throttle response and roasting the tires at will. However, I also remember struggling to get a good 60' at the track with it as well. I'm thinking about either porting the TB or buying a ported one for my car, but I'm just not sure that it's worth it for the reason I mentioned above. After all, what good is an extra 5hp or so if you're losing it at the launch?
Discussion?
Ideas?
Old Aug 8, 2007 | 12:12 PM
2000GTP's Avatar
It really won't make a difference unless you step into some of the bigger mods like a heads/cam setup.
Old Aug 8, 2007 | 12:22 PM
oneclean97z's Avatar
^^^what he said
Old Aug 9, 2007 | 06:46 AM
teke184's Avatar
yeah...and a ported TB won't be the deciding factor on whether or not you can "roast the tires at will"...or get bad launches due to traction issues.
Old Aug 9, 2007 | 09:04 AM
6stringer's Avatar
Really?
I found that the increased throttle response made it harder to roll into the throttle when launching which made it harder to keep from breaking loose on launches.
Old Aug 9, 2007 | 10:03 AM
WS6NIGHTMARE's Avatar
I think you need to be at least a full bolt on car before you start looking at a TB. And then, you cant go too big.
Old Aug 9, 2007 | 01:07 PM
96ZCamaro's Avatar
I dont think it could hurt really.
Old Aug 10, 2007 | 07:28 AM
teke184's Avatar
"Really?
you REALLY think that 3-5hp...if that at low rpm...is going to affect whether you break traction?
there are a dozen other factors that could have affected your traction.
Old Aug 10, 2007 | 07:48 AM
6stringer's Avatar
"[i]you REALLY think that 3-5hp...if that at low rpm...is going to affect whether you break traction?
I don't really think that you see any actual HP gains until you hit the upper RPMs. I was refering to how the feel of the pedal changes. Since the throttle body flows better, the car seems to want to jump in a good bit faster than with a stock unit on. I'm guessing from your response that you've never had any issues trying to get down a launch after putting on a ported TB. From that perspective, maybe I just suck at driving?
Old Aug 10, 2007 | 08:33 AM
"Increased throttle response" is an illusion. You either have more HP/torque, which makes the car more responsive, or you don't. The rate at which the throttle opens is not the issue. Just force the pedal to the floor faster with a heavier foot, or put a weaker spring on the TB if you think that's going to make difference.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
RedLineRev
Jan 23, 2003 03:51 PM
