tranny temp reads -40 on scan tool - code 59
Old Jul 29, 2007 | 11:22 AM
98creamsickle's Avatar
ok, I just got my tranny rebuilt by a friend, It was driving good for like two days and then after stepping on it once, then I slowed down to a stop sign and when I took off it only has 1st and 2nd! so i scanned it and it said code 59 low tranny temp, then I went to the specs and it was at -40!!! so it sounds like a bad tranny temp sensor ( which is apart of the transmission range pressure switch assy.), but would that stop me from being able to go into 3rd and OD???? HELP!
Old Jul 30, 2007 | 05:46 PM
Might get an answer in "Drivetrain".... not in LT1/LT4 Engine Tech. I'll move it for you.
Old Jul 30, 2007 | 11:55 PM
ok, heres the deal now... i changed my pressure manifold switch which corrected some of my problem... now if i floor it, it will shift from 2nd to 3rd, but if I take off like normal it stays stuck in 2nd... when i plug the scan tool in again, it says im going 25 when I was really going 40ish, would my speed sensor be a problem with me being able to shift when supposed to?? need help guys
Old Jul 31, 2007 | 07:02 PM
12SCNDZ's Avatar
Yes. The computer uses the speed sensor to calibrate the transmissions shift timing.
Frank
CPT
Old Jul 31, 2007 | 07:05 PM
Performabuilt's Avatar
Supporting Vendor
Yes the speed sensor does affect shift timing , However I would really look at car electrical grounds two issues like that coming up at once troubles me.
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
