offset question
Old Dec 2, 2006 | 09:40 PM
camarolt4ss's Avatar
offset question
can i use a 19X9 front, 19X10 rear with an offset that is 41 front & 42 rear bolt pattern is 5X114.3 with a center bore of 67
thnx
Old Dec 3, 2006 | 12:43 AM
Zack's Avatar
forget the offset, the bolt pattern is wrong
Old Dec 3, 2006 | 08:11 AM
ya thought so, just checking tho, i can use those on the wifes sunfire tho im sure, just off the top of my head i couldnt remember what the bolt pattern was on the sunchicken vs the camaro
Old Dec 3, 2006 | 11:04 AM
5 x 4.75" (120.65mm)
Old Dec 3, 2006 | 11:49 AM
Zack's Avatar
sunfire is 5-100...plus those wheels would be waaay to wide for that car
Old Dec 3, 2006 | 12:32 PM
na mine is a custom widebody, +4" so it will fit
so whats the offset needed to run a 19" on a camaro?? will a 64mm work if i wana run 19's front and rear??
Old Dec 3, 2006 | 05:12 PM
There a discussion in the FAQ at the top of the page regarding the acceptable range of offsets for various width wheels. The diameter of the wheels doesn't affect much, except in the front if you are trying to run a really wide wheel and keep it under the fender. The larger diameter wheels can run a bit more backspace, because the steering knuckle is bending backwards, away from the wheel rim as the diamter increases.
Old Dec 3, 2006 | 05:33 PM
well ok i read over that, but still isnt really giving me an answer to if the 64mm will work, maybe its just me (late nite, still tired) but some one care to help me out with this lol
thnx
Old Dec 3, 2006 | 10:52 PM
Whether is will "work" depends on the width of the wheel(s).... which you didn't mention.... unless you are talking about the same widths mentioned in your intial post?????
Old Dec 4, 2006 | 08:49 AM
8.5-9.5 front and 9.5-10 in the rear, looking to run the same 275 rubber as i have now, no need to go larger right now
Old Dec 11, 2006 | 06:58 PM
ok guys got some specs here on a
19x10 with a +79 mm offset
will they work on the car, or will they rub or tuck right? or....
let me know
thnx
Old Dec 12, 2006 | 07:12 AM
let me know
thnx
From the FAQ on "WHAT OFFSET DO I NEED FOR MY 4TH GEN:"
10.0":
Tire edge outside fender = +38mm
Limited by backspace on front = +50mm
Tire edge slightly inside fender = +55mm
Limited by backspace on rear = +62mm
From the FAQ on "C6 OEM WHEELS ON A 4th GEN:"
• Offset +79 (19x10 inch Wheels)
3. I got to the rear, and I immediately noticed a problem. I pulled the wheel off, massaged the inner wheel wells, as well as the quarter panel inner section, with no results.
4. I decided to buy some bolt in adapters, through ebay, being that I found the best price (I beleive it was around $60 for a set of rear spacers 1.25" including locking bolts.
Its all there in the FAQ.
Old Dec 12, 2006 | 02:40 PM
i work to many hours a day bro to look through it all, thats why im just asking if they would fit, and honestly what that says to me, doesnt make much sense right now, lol
just tell me yes or no lol...
i see buddy got some adapters, did they fix the problem tho? and are adapters a good idea??
HectorM52
Jul 30, 2017 11:46 AM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
redzed
Sep 4, 2002 06:22 PM
