Could this gain some Horses?
Old Oct 12, 2006 | 12:06 AM
ajlew9428's Avatar
I was just thinking today, about ways to make some power on my engine w/o buying anything, and came up with this.If you took off Air, and took off AC, then got a smaller belt, could you gain some hp from parasitic loss? Also could you fab up some tranny lines to run through the condenser, and have it act as a massive tranny cooler? Just wondering
Old Oct 12, 2006 | 12:19 AM
ibanez6rg's Avatar
Re: Could this gain some Horses?
Nothing you mentioned is worth the trouble.
Old Oct 12, 2006 | 12:32 AM
ajlew9428's Avatar
it is for me. Ac not working(compressor), Secondary Air system screwd up. Since I have ttops, and never use AC, and also is a lot cheaper to delete the 2, clean up the engine bay making future mods and maintanance easier, and also lose some weight, and gain a little hp, its definitely worth it to me. I just wanna know if you can use the condensor as a tranny cooler
Old Oct 12, 2006 | 12:55 AM
johnny6's Avatar
You'll get a couple of ponies from a/c and air removal don't expect to feel a difference.
Old Oct 12, 2006 | 03:13 AM
2000GTP's Avatar
The air pump is electric driven on the 4th gens, not belt driven so it shouldn't effect you. As for the A/C, if you don't have the unit working, then it shouldn't cause you loss either, but if you remove it, it will take a decent amount of weight off your front end.
Old Oct 12, 2006 | 05:30 AM
Generally a good idea to include basic data about your car - year, model, engine, tranny and any major mods - so people can give an accurate answer.
If its a 4th Gen, when you delete the A/C you can't shorten the belt. You need to install an idler pulley in place of the A/C compressor clutch. All you have deleted is a minor inertial load from the rotating portion of the clutch, which isn't much. As already noted above, the AIR pump is electric driven and doesn't even run past the first couple minutes after startup, so no savings there. Weight reduction is the only real gain on both items.
Using the condensor as a large tranny cooler would probably hurt more than it helps, since now the entire radiator is covered by the tranny cooler and the hot air out the back of the condensor is being used to cool the entire radiator surface, reducing its heat removal capability and forcing the fans to run more.
Old Oct 12, 2006 | 09:29 AM
ajlew9428's Avatar
I didnt think of that injuneer. Makes a lot of sense. Ill prolly end up getting rid of them if i cant get them working
Old Oct 12, 2006 | 10:42 AM
myslowcamaro's Avatar
why cant you? i think my mechanic put a shorter belt on temp. when my a/c clutch went
Old Oct 12, 2006 | 11:11 AM
FuryZ28's Avatar
I think it has to do with the grooves on the pulleys. The PS & tensioner pulley, for example, has a smooth pulley for the backside of the belt, whereas the alternator, crank, and A/C have grooved pulleys for the ribs of the belt to fit into...
Old Oct 12, 2006 | 04:27 PM
I'm guessing from his screen name that its a 94 4th Gen. With the LT1, there is no way to reroute the belt when you delete the A/C, at least not without custom brackets, relocating the alternator and/or PS pump. May be possible with an LS1 though.
Old Oct 12, 2006 | 04:31 PM
Sick97SS's Avatar
yea, if you enjoy having swampass all summer, go ahead and remove your A/C.
Old Oct 12, 2006 | 04:43 PM
ajlew9428's Avatar
ya, I think Ill just try to fix it. It is a 94, I need to make a sig
Old Oct 13, 2006 | 08:47 AM
30AnvZ28's Avatar
lol... even with leather seats, you still end up with swampass... thats why I love the houndstooth seats... the look of leather, but the center of cloth.
MDZ28
11
Sep 24, 2015 09:15 AM
colts0455
Sep 22, 2015 02:03 PM
cmsmith
Sep 14, 2015 09:25 PM
Daluchman1974
Sep 11, 2015 06:12 AM
colts0455
Sep 2, 2015 12:41 PM
