Flushing heater core?
Old Oct 12, 2006 | 06:21 PM
reamo04's Avatar
Well guys, my heater core is plugged up pretty good. Took it to my friend who owns his own mechanic shop, and we determined its the heater core by putting a heat-gun and checking the temperateures of the go to and return hoses. Going in was 185, leaving was 115....so it wasn't getting coolant to the heater core. The thermostat is new, so i know its not that.
Now, how do i flush out the core?
Okay, i figured out how to do it, but where are the 2 hoses? I found one that runs under the CAI sorta, wheres the other one?
Old Oct 12, 2006 | 06:32 PM
blackztpi's Avatar
Re: Flushing heater core?
probably plugged or defective. your only chance would be to pressure flush it at a shop...check the prices...sometimes better to replace
Old Oct 12, 2006 | 06:35 PM
reamo04's Avatar
i'm going to try to flush it out w/ a garden hose/pressure washer first. Prices around here are all 100+ to do it, and i'd rather not have to pay for it. Where are the hoses at tho?
Old Oct 12, 2006 | 06:44 PM
reamo04's Avatar
ok, i found the other hose (right on top, the one that has the tee-intersection on it). Anything I should know about this before i do it tomorrow?
Old Oct 12, 2006 | 06:57 PM
seawolf06's Avatar
Maybe you should just flush the whole system. If something blocked up the heater, chances are something else might get blocked as well. I used the Prestone system flush stuff. It works really well, but it puts a LOT of air into the system. Just follow the directions and you'll be good. It's also best if you unplug one of the coolant plugs in the bottom of the block.
Old Oct 12, 2006 | 07:10 PM
reamo04's Avatar
Well guys, unfortunately i cannot get my hands to the back of the firewall to unplug the hose clamps to flush it out that way. Any other suggestions?
Old Oct 12, 2006 | 07:36 PM
reamo04's Avatar
Are the "coolant drain plugs" on the block on the bottom of the radiator, or what?
Old Oct 12, 2006 | 08:02 PM
FlamingChicken's Avatar
there is a drain at the bottom passenger side of the radiator and at the bottom of the block on both sides. the pass side should be your knock sensor and the drivers side is just a bolt that looks like it goes to nowhere
Old Oct 12, 2006 | 08:16 PM
reamo04's Avatar
Thanks guys, you have all been a great help.
Old Oct 12, 2006 | 10:37 PM
Remove the heater hoses at the water pump. That's the easiest way.
Old Oct 12, 2006 | 10:48 PM
RAT454's Avatar
What year are you working with?
Old Oct 12, 2006 | 11:07 PM
Add a "signature" with basic info about your car - year, model, engine, tranny and any major mods. That way people can give you accurate answers without guessing or ASSuming.
Old Oct 13, 2006 | 01:05 PM
AlfredB18's Avatar
If your core is that plugged up, replace it.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
