ES Tranny mount ???
Old Jul 10, 2006 | 03:29 PM
Wicked 97TA's Avatar
ES Tranny mount ???
I just bought an Energy Suspension tranny mount from AutoZone for my '94 T/A. Do I have to use the spacer plate that comes with it? I did a search on this but really couldn't find a clear cut answer.
Old Jul 10, 2006 | 07:42 PM
RedWS6TA's Avatar
Re: ES Tranny mount ???
all i did was grind down the two humps and the use the spacer. that way it sits flat.
Old Jul 11, 2006 | 09:43 AM
matLT1's Avatar
Yes, the spacer is there for a purpose (the purpose I am uncertain of). However, the directions do say to make certain to put the spacer in because it is part of the design. Also, you don't need to grind the humps because as you tighten the mount, they will naturally be flattened.
Old Jul 11, 2006 | 12:26 PM
12SCNDZ's Avatar
If you install the spacer plate, it throws the pinion angle off and gives you a wicked vibration. It will be much less noticeable without the plate.
Frank
CPT
Old Jul 11, 2006 | 01:58 PM
ttop1986's Avatar
I used the plate and mine doesn't vibrate much.
Old Jul 11, 2006 | 02:21 PM
StudyTime's Avatar
Those bumps don't naturally go away. Grind them off on a bench grinder. Removing the bumps and plate cured a lot of my vibration issue with my mount.
Ben T.
Old Jul 12, 2006 | 08:42 AM
Capn Pete's Avatar
I had an ES poly mount in my car for about 1 season, and I put back my factory LS1 mount. I couldn't stand the vibrations, although I HAD the plate installed. General concensus is run WITHOUT that plate and it should be ok. I didn't have the time to "experiment" with it ... I just wanted the car smoothed out, so I just put the LS1 mount back in. Eventually if/when the LS1 mount wears out, maybe I'll put the ES mount back, but without the plate this time?
Old Jul 12, 2006 | 01:28 PM
I used the ES poly for 4 years with my T56.... first with the stock torque arm, and later with a Spohn TA, and never had a problem with any sort of vibrations, or with the pinion angle. It was installed exactly as the ES instructions showed, including the pre-load plate and all the bumps. Now 9 years after I bought it, its holding up the tail end of my TH400/Gear Vendor combo, and still doing its job.
Old Jul 15, 2006 | 12:23 AM
pricelessz28's Avatar
I didn't se the plate either. i haven't noticed any more vibrations than usual
Old Jul 15, 2006 | 02:22 AM
Sleeper_Z's Avatar
I put one in my car when it was still an auto. I left the plate out because WITH the plate it was taller than the stock one. I figured it would alter the pinion angle. I had zero vibration without the plate. My friend put on in his car WITH the plate and it vibrated like crazy. I removed the plate and it went away. Either the plate alters the pinion angle OR the plate preloads the mount so much that it makes it to stiff and transfers all the vibration from the road, t-arm and drivetrain. I left mine out and its been in my car without any trouble what so ever for 3 years now.
Jeremy
Collinjacobfowl
Jul 30, 2015 09:35 PM
wesley81
Jul 27, 2015 11:31 AM
Jul 10, 2015 02:23 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
