closed loop at WOT??? log included
Old May 27, 2006 | 09:21 PM
busta9876's Avatar
I'm helping a friend tune his car, I sold him the motor. It's a 381 cu in LT1, LT4 hot cam, 58mm TB, ported heads, 30lb svo injectors. On a datalog I noticed it stays in closed loop during a WOT pass
I've included the datalog from the pass, its around 1540 seconds on the log using DataMaster EE. Or Rec#9454
Long term goes to 128 and does not change
Short term bounces back and forth, even at 100% TPS and the O2's are flip flopping like normal, but shouldnt it be in PE?
Or is it lean and the computer is adding fuel for safty, even though its supposed to be open loop?
the closed loop indicator at the top never turned off.
http://www.lt1swap.com/ian_first_log.uni
Old May 27, 2006 | 11:56 PM
Re: closed loop at WOT??? log included
If you post your data log in ".csv" format, people without DataMaster can look at it with Excel.
The "closed loop" indicator simply shows that all the conditions to enable closed loop have been met - O2 sensors heated up, coolant heated up and timer timed out. It doesn't mean PE mode is not enabled. But if your short terms and O2 sensors are cycling, you definitely have a problem.
Old May 28, 2006 | 09:30 AM
busta9876's Avatar
i think i found the problem
log showd 100% TPS, but only 4.19 volts, then it went to 4.51 volts and it intg went to 128 and o2 mv stayed over 800
will look at tps adjustment.
DirtyDaveW
Dec 1, 2016 05:37 PM
maybe2fast
Mar 16, 2015 11:59 AM
armedtrigger
Feb 24, 2015 08:30 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
