do i need a new u joint
Old Oct 23, 2005 | 03:47 PM
red 95 z28 lt1's Avatar
i just bought a moser 12 bolt with a 1310 series yoke do i need to get a diffrent u joint or will everything bolt right up (stock drive shaft)
Old Oct 23, 2005 | 09:33 PM
rskrause's Avatar
Moderator
Re: do i need a new u joint
If you need a 12-bolt, you are going to need a better DS and 1350 U-joints as well. In any case, you stock DS is going to be a little long with the Moser, you can probably get away with it for a while if you have to though. Only way to tell is to bolt it up and see how it looks.
Rich
Old Oct 24, 2005 | 06:55 PM
well i will be driving the car everyday and wont full out race the car untill i get a new driveshaft but is it ok for everyday normal driving?
also i thought a 1350 u joint will only work in a 1350 pinion yoke i have a 1310 yoke
Old Oct 24, 2005 | 08:51 PM
rskrause's Avatar
Moderator
Yes, it will be fine for a DD. Yes, they have to match. When you upgrade the DS, get beefier U-joints.
Rich
Old Oct 24, 2005 | 11:12 PM
ok thanks
Victor Lamb
Aug 26, 2017 02:52 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
blac94Z
15
Mar 2, 2015 12:00 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
BBB
Advanced Tech
Feb 2, 2003 11:52 PM
