U-joint and Driveshaft questions
Old Feb 2, 2003 | 06:40 PM
BBB's Avatar
BBB
If I am not mistaken 3rd and 4th gens come with 1310 series U-joints. Right?
I am upgrading the housing in my 95 TA to a 12 bolt Moser so I don't have to worry about blowing up the rear in the coming drag race season. What I need to know is how durable are 1310 joints and if the 1310/1350 u-joints are any stronger (what I am referring to is the half and half joint used to connect a 1350 yolk to a 1310 axle). How much hp can the 1310 hold, the 1310/1350, and the 1350?
I am going to order the axle with the 1350 yolk, but I need to know about budgeting for a new driveshaft. I already have the GMPP aluminum shaft (with slight high RPM vibrations) and would like opinions on a cromoly shaft or a carbon fiber shaft.
Who all has jumped through these hoops already?
BBB
Old Feb 2, 2003 | 09:36 PM
zturbo's Avatar
stock is 1310 you are correct. The 1310-1350 conversion ujoint is imo of course junk. I would if you are planning on giving the rear alot of abuse get a 1350 setup. I am going to use a Mark Williams driveshaft, but I do like the Denny's Nitrous Ready shaft. Get it with solid u-joints (1350) and you should not have a problem with the shaft.
Old Feb 2, 2003 | 11:52 PM
Soma07's Avatar
Everyone says the stock joints are 1310's but I measured mine and they are they were too small be a 1310. The retaining clips on the 1310 are also in the wrong place vs. stock. FWIW my measurements matched a Saginaw 3-R joint perfectly.
Not trying to argue with anyone but if you have a set of calipers you may want to measure the U-joint in the DS you have now just to verify. It only takes a few min to drop the DS.
You can find the dimensions for most U-joints here:
http://www.drivelineshop.com/specsheet.htm
But if you're replaceing everyhing with 1350 stuff then it doesnt matter...
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ElkyRacer
Sep 19, 2002 02:33 PM
