285/35/17s with Prokit?
Old Sep 17, 2005 | 01:47 PM
FNDRB58's Avatar
Will the Eibach Prokit work with 285/35/17s in the rear or will I have rubbing issues?
Old Sep 18, 2005 | 03:28 AM
96m6lt1's Avatar
Re: 285/35/17s with Prokit?
you should be fine,may rub under hard turns though..mine did till i massaged the inner wheel well
Old Sep 18, 2005 | 08:19 AM
fly89gta's Avatar
I would say no. At least I hope not because I might be running 275/35/18's in the back soon along with a prokit.
Old Sep 18, 2005 | 09:09 PM
Where are you finding a 285/35-17? Tire Rack doesn't even list that size. If you do find them, they will be about 3/4" smaller in diameter than the stock tire.
Whether they will rub depends on the offset and width of the wheel you put them on.
Old Sep 18, 2005 | 09:45 PM
My Iroc Z28's Avatar
i was gonna say the samething i think he means 285/40/17 and i've seen guys run those with 9'' wheels along with 315's with 11'' wheels with no issues as long as you are not using stock shocks.
Old Sep 19, 2005 | 07:29 PM
FNDRB58's Avatar
40, yep. Do people massage the inner fender more to clear room for the width of the tire or heighth or usually both? I'll be putting these on 10s in the rear.
Also, how would 275s look on the front with 10s compared to the 285/10s in the rear? The other option would be using 8s in the front...but what would be the best width tire for that, 255?
Thanks.
Old Sep 20, 2005 | 09:29 AM
Whether you will have a problem depends on the offset of the wheel.
To large an offset, and the inside edge of the tire is into the inner fender liner (hammering required) and the inside edge of the rim can catch on the bump stop bracket (cut-off or grinding required). Too little offset, and the outside edge of the tire is right under the fender lip, and the lip cuts into the edge of the tire (roll the lip). Way too little offset, and the tire is outside of the fender and on a lowered car, the fender rides on top of the tire. Generally, you don't get into trouble with the top surface of the tire going up into the fender liner. I had my car down 1" in the back with 275/40-17's and a 17x9.5" 49mm offset wheel, and nothing hit anywhere.
With a 285/40-17 and the correct offset (45-56mm), you will not have any problems - as long as the wheel has the correct offset.
I think you will find there is very little difference in the appearance of the 275/40 and the 285/40. If you start looking at different brands, some manufacturer's 275's are just about the same width as other manufacturer's 285's. I'd put the same tire on all 4 corners if you want to be able to extend the tire life by rotating them.
Old Sep 20, 2005 | 05:35 PM
FNDRB58's Avatar
Ok, so 285/40-17s all around on 10s should work with the Prokit, cool. The other option I am considering primarily for aesthetic reasons would be 8s in the front. I've always liked a smaller whell in the front. Would 255s be best on 8s and are there any negatives to 8s in the front and 10s in the back other than not being able to rotate? How much more mileage do you really get by rotating tires?
Old Sep 20, 2005 | 06:27 PM
255's on a 8'' would work, the mileage difference would be different from tire to tire it depends on the tire thread wear rating, if it's low then don't expect them to last long if it's high expect them to last longer also depends on driving habits. Expect for 180-300 tire wear rating to tires in that size.
Old Sep 20, 2005 | 07:00 PM
FNDRB58's Avatar
Actually, the more I think about it, 8s vs 10s doesn't really change the aesthetics. I think what I really like is a smaller diameter front wheel. Thoughts on a 255/16 on 8s for fronts and 285/17 on 10s for rear?
faSSt97
Dec 10, 2003 11:33 PM
tweaked96z28
Nov 20, 2003 06:58 PM
OLDDIRT
Nov 20, 2003 05:55 AM
89irocz23
Nov 2, 2003 12:25 AM
DubbyZ28Camaro
Oct 20, 2003 04:31 PM
