Eibach prokit install instr for 95z??
Old Nov 18, 2003 | 06:45 PM
OLDDIRT's Avatar
which forum can I find install instructions for eibach prokit springs for my 95z vert. Thanks, John A
Old Nov 18, 2003 | 07:17 PM
ibanez6rg's Avatar
I'd imagine LT1 tech, try the Search and see what you can find.
Old Nov 18, 2003 | 09:43 PM
I have combined instructions for Eibach Pro-Kit + HAL/QA1 shocks, in painful detail..... here.
Old Nov 19, 2003 | 09:35 AM
DohHunter's Avatar
Check LS1howto.com, there is a great writeup there.
It's the one i used, and I had never touched springs/struts before.
Old Nov 19, 2003 | 02:19 PM
blackbirdta's Avatar
is it possible to do it without a lift or is it a pain in the ***?
Old Nov 20, 2003 | 05:55 AM
All you need is two jack stands and a floor jack. Rear springs require you get the back of the car far enough off the ground on jack stands, to allow the rear axle to be dropped several inches after the shocks are unbolted.
Front simply requires that you put the car on jack stands sufficient to pull the wheel assembly down a couple of inches after you unbolt the top spring/shock mount from the shock tower.
There are no "struts" on a 4th Gen.... they are "coil over shocks".
Nov 18, 2023 07:21 PM
CamaroHeed
Mar 18, 2020 09:50 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Dec 1, 2014 08:08 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
