HOOSIER Drag Radials results!!!!!
Old Jun 14, 2005 | 04:32 PM
timelord's Avatar
HOOSIER [D.O.T.]Drag Radials results!!!!!
Hello,,,,just a note to let you know how the new Hoosier Drag Radials compare to
BFG DRs[255/50/16]Best ever 60ft 1.802
M/T ET STREETS[26/10/16]Best ever 60ft 1.78
Hoosier slicks[26/10/15]Best ever 60ft 1.65
Ran the DRs for 3 weekends and the only tire that I have run that sticks better is the slick.
Got 13 runs in Sunday on a hot and very humid track and still managed consistant 1.71s with a worst 60ft of 1.74.
The tire needs practically no burnout,just roll through the water stop at the edge apply linelock 2 seconds and spin to the line.
The tire performs far better than the ET STREET in the traps,it isn't wandering all over the place.
I found that 18-19 lbs gives me the best results with my heavy car[3700 lbs]
They are also less drag at the other end than the slicks,allthough I will retry the slicks just to be sure this weekend.
I have yet to run my friend with a very similar car on M/T DRs,I want to see who wins in a heads up 60ft race.
I was pleased with the results and will let you know of any more improvements.
Thank you !!
Serge.
Old Sep 19, 2005 | 12:53 PM
Tekprodave's Avatar
Re: HOOSIER Drag Radials results!!!!!
good info thanks.
Did you have to run tubes with the hoosier slicks?
Old Sep 19, 2005 | 01:25 PM
timelord's Avatar
I have a slow car (12.40s) that does not require much give from the slicks,at 20psi inflation they hook great.
If you need soft psi to bite,say 10-12 psi then tubes are recommended(and the rim screws to go with them on violent cars).
Old Sep 19, 2005 | 01:38 PM
Tekprodave's Avatar
We have similar cars so that's cool. I've been running the hoosier quick time pros at 15psi but I'm afraid I might need little more since I'm trying to cut a 1.5x 60ft time. It sounds like I could run the drag slicks without tubes at about 15psi and be ok. Thanks again for the info.
Old Sep 19, 2005 | 06:37 PM
timelord's Avatar
I see where the difference lies,,,,
You + car = 3050
Me +car= 3630 ,(no I do not weigh 600 LBS)
Old Sep 19, 2005 | 06:41 PM
Tekprodave's Avatar
You + car = 3050
I've discovered the wonders of weight reduction. The only problem is that I think I went too far.
Maybe if I put 600# in the back I could get better traction.
Old Sep 20, 2005 | 08:49 PM
DMcRacer's Avatar
It sounds like the Hoosiers are going to work about like the M/T drag radials. My best 60ft on M/T dr's is 1.43, I've pulled many 1.64 to 1.66's on them. Thats with a BMR pan hard rod, polly/rubber BMR lca's, stock shocks and springs in the rear, nothing fancy. Hals up front. Stock torque arm.
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
