Z28 vs SS
Old May 11, 2005 | 01:53 AM
chevyhorsepower's Avatar
Z28 vs SS
What's the difference in motors between an ss and a z-28 from 1998 to 2004? Do they both have the LS-1?
Old May 11, 2005 | 02:06 AM
sir dyno's Avatar
Re: Z28 vs SS
Yes, the both have the ls1 engine. They stopped making the camaro in 2002 not 04.
Old May 11, 2005 | 05:32 AM
FedZ's Avatar
Re: Z28 vs SS
The motors evolved in parallel over the years and were the same for both the SS and Z, the SS got the Ram Air and allegedly free-flowing exhaust. The SS was mainly an appearance package with the hood, rear spoiler and wheels.
Old May 11, 2005 | 06:32 AM
psychocabbage's Avatar
Re: Z28 vs SS
1998-2002 - LS1 motors
1993-1997 - LT1 motors (with 1993 being speed density and every other after using MAF)
SS is essentially cosmetic.. On the dyno and at the drag strip the numbers will be indentical with more Z28's winning due to the lower rotational weight (16" wheels weigh less than 17" ones, 245's will provide less rolling resistance over 275's)
If the SS has the optional suspension package it would win on a road course or AutoX course..
Here is some more info:
Differences Between LS1 Years
1998
1. Had differnet casting heads which had perimeter bolts and valve covers.
2. Ignition coils were mounted to the valve covers one at a time.
3. The water temp gauge actually works.
4. Only LS1 year to not have an oil life monitor
5. WS6s had single outlet exhaust (all others had duals)
6. Steering wheel controls were completely different part with indentations on the buttons, and were better built
7. Only year that Purple, Gold, and Green were available
8. Some very early Trans Ams came with LT1 style headrests (see my sig for pictures)
9. Rear hatch release was poorly designed and often caused problems releasing mechanism
10. Early model 98 Monsoon stereos didnt have capability to control 12-disc CD changer
11. 1998-1999 automatic transmission LS1s could be started in 1st gear even with the shifter in 2nd. Starting 2000, if you put the shifter in 2, it would start off in 2, even from a stop.
12. 1998-1999 LS1 cars had a smaller throttle body cam, which caused the throttle to open to WOT faster than 2000+ cars
13. 1998 cars had 28 lb fuel injectors from the factory
14. 1998-2000 cars had a larger cam than the 01-02 cars
15. 1998-1999 cars had more restrictive exhaust manifolds
16. 1998-2000 cars had an LS1 intake with EGR
17. 1998 and some early 1999 cars had blue outside rear view mirrors
18. 1998 only LS1 blocks had a much smaller cylinder sleeve that only tolerated a .005" hone
19. Last year F-body to use the old 15.5 gallon fuel tank.
20. Only year LS1 F-body to contain a gascap with a tether long enough to actually hang from the fuel door while open
21. Only year LS1 F-body to not contain the famous GM black box used in the event of an accident to record up to 5 seconds of pre-crash data
22. 1998 only cars had a different PCV system with the PCV valve located above the passenger side valve cover
23. 1998 only cars did not have a low-fuel light
24. 1998 cars have a completely different PCM from 99+ cars
25. A production shortage of F-body cams caused the use of a C5 cam to be installed in F-body LS1s for a very short time
1999
1. 1999-2000 cars switched to 26 lb fuel injectors
2. Cylinder heads and valve covers redesigned to have center bolts instead of perimeter bolts. Other than that, the heads were the same.
3. Redesigned cylinder sleeves that allowed for a small bore, up from .005" in 1998 models.
4. Midyear model change to a cheaper steering wheel audio control button without finger indentations, and cheaper built
5. 1999 cars continued the LS1 intake with EGR provisions
6. 1999 cars continued more restrictive exhaust manifolds and larger cam
7. Only year that Hugger Orange was available (Camaro only)
8. 30th Anniversary Trans Am available with special blue and white paint package and blue clear coated WS6 wheels
9. Switch to larger 16.8 gallon fuel tank to meet new emissions requirements.
10. Gascap tether was shorter and could no longer be used to hang on the gas door when open.
11. Company wide change added black boxes to record up to 5 seconds of data before a crash
12. Rear hatch release was redesigned with stiffer spring that released the hatch better
13. Water temp gauge was redesigned to work basically as a dummy gauge and only show an overheat condition.
14. An oil life monitor was added to all LS1s, thus changing the gauge cluster a little to show the oil life reset swtich
15. 1999-02 cars had a different PCV system with the valve located to the side of the intake manifold
16. Early production 1999 Trans Ams still had the blue outside mirrors, but a midyear change went to the non-tinted ones
17. only year for Bright Blue Metallic.
2000
1. Redesigned exhaust manifolds for new emissions standard actually flowed better and created a little more HP.
2. 2000 continued use of LS1 Intake, EGR, smaller cam, and 26 lb fuel injectors
3. Added rear child seat safety hooks to interior per federal requirements
4. Very early run of WS6s had "salad shooter" style rims. A production change switched back to standard 5-spoke WS6 rims.
5. Camaros got redesigned 10-spoke base rims, and SSs came with new 10-spoke rim design
6. First year of Monterey Maple Metallic paint
7. Charcoal (grayish) interior was replaced with Ebony (almost black) leather interior
8. Cloth interior cars got new rainbow colored cloth patterns
9. Camaros only got the Pontiac steering wheel with optional audio controls
10. Throttle body cam was increased in size to slow the speed at which the car reaches WOT
11. Automatic transmission cars were reprogrammed to allow a car to start off in 2nd gear from a stop when the shift lever is put into 2.
12. The last year a WS6 Formula was offered
13. Starting 2000 intake lids contained a seperate breather filter
2001
1. A small percentage of 2001 and 2002 LS1s actually had LS6 blocks which had a different part number and a darker metal cast
2. Starting 2001, all LS1s came with an LS6 intake manifold without an EGR system
3. Advertised HP output was changed from 305 to 310 on base LS1s and from 320 to 325 on WS6s and SSs
4. 2001-02 cars have a smaller cam from the Vortec truck engines to increase low end torque
5. 2001-02 cars had 28 lb fuel injectors like the 98 cars (albeit different part numbers)
6. WS6 cars had a redesigned 5 spoke rim which was more wavy
7. WS6 cars got less suspension upgrades from a base Trans Am suspension than previous years
8. Manual transmission cars came with upgraded clutch and associated hydraulics compared to the earlier years.
2002 - Last year of the F-body
1. 35th Annivesary edition of the Camaro, and Collectors Edition Trans Am available
2. 2002 LS1 head gaskets redesigned. The new ones are a pressed metal, as opposed to the graphite ones and are no longer specific to the side of the car theyre installed on
3. 2002 cars continued with the LS6 intake, 28 lb fuel inectors and smaller truck cam
4. 2002 continued the use of an LS6 block in some LS1 F-bodies
5. A factory supported optional 345 HP option could be ordered from SLP
6. Manual transmission cars continued to use upgraded hydraulics over 98-00 Fbodies.
7. Some 2002 model F-bodies came with a revised rear view mirror that had the map light buttons on the bottom, rather than the front.
Old May 11, 2005 | 09:17 AM
Greed4Speed's Avatar
Re: Z28 vs SS
An SS IS a Z28.
Old May 11, 2005 | 09:33 AM
Shempy's Avatar
Re: Z28 vs SS
The power differences aren't great, but many of the SS benefits came through the SS-only options. The Bilstein and 1LE suspension options were far superior to Z28's. The optional SLP dual/dual exhaust is one of the better flowing systems out there. The standard 17x9 wheel/tire pkg is also superior for handling (and looks) to the Z28.
Old May 11, 2005 | 11:24 AM
MRZ28HO's Avatar
Re: Z28 vs SS
Not to nit pick here, but my 2001 Camaro SS is an early production and it came factory equipped with the "2002 revised rear view mirror" with the buttons on the bottom, so that statement is false.
Old May 11, 2005 | 11:37 AM
Antz97ZNJ's Avatar
Re: Z28 vs SS
SS is mostly an appearance package same engine, same paper...even though the SS has more power thats mostly on paper.
Old May 11, 2005 | 12:16 PM
roadkillZ28's Avatar
Re: Z28 vs SS
psychocabbage / great details man ... however you didnt mention the ASR switch in which year came?
I believe ’99+ cars had ASR system…. right? but why my z ’00 doesn’t have it (from the dealer)?
and oh yea without keyless entry?!
Old May 11, 2005 | 03:03 PM
angel71rs's Avatar
Re: Z28 vs SS
My 98 has it. It was an option.
Old May 11, 2005 | 03:11 PM
falchulk's Avatar
Re: Z28 vs SS
Mine did also. It also has a 35th anniversiry insert on the dash even though its build date was in March 01.
Old May 11, 2005 | 04:40 PM
Re: Z28 vs SS
my car is a stripper.. has hardly any options..
just T-tops, factory Hurst and leather steeringwheel..
thats it.. no power anything..
hence why I added Cruise Control! woot!
Old May 11, 2005 | 05:25 PM
99blackSS's Avatar
Re: Z28 vs SS
http://web.camaross.com/forums/showthread.php?t=339951
Old May 11, 2005 | 10:06 PM
Strahley's Avatar
Re: Z28 vs SS
The only difference between a Z28 and an SS is appearance on the LS1 cars, don't let anyone get you to beleive otherwise
Old May 11, 2005 | 10:58 PM
CrabhartZ28's Avatar
Re: Z28 vs SS
They also retain their value better, and people are way more biased toward them. But if you meet an SS guy who thinks he can take your modded Z, he deserves to be demolished.
