Break Problems
Old Mar 31, 2005 | 07:48 PM
thelastz28's Avatar
Exclamation Break Problems
I have a 2002 Z28 and it has 25K miles. When I am at Highway speeds and hit the break pedal, my steering wheel shakes really bad. Does anyone know why this is happening? How can I fix it? Thanks.
Old Mar 31, 2005 | 07:50 PM
97s10ondubs's Avatar
Re: Break Problems
warped rotors it sounds like, my dads van did that when the rotors got messed up
Old Mar 31, 2005 | 08:09 PM
dabez1's Avatar
Re: Break Problems
Yup, might want to check out the rotors
Old Mar 31, 2005 | 08:16 PM
thelastz28's Avatar
Re: Break Problems
Thanks a lot guys. I will have to replace them. Any recommendations?
Old Mar 31, 2005 | 09:14 PM
Capn Pete's Avatar
Re: Break Problems
If you don't want them to warp prematurely again, then go aftermarket ... I don't know which brands are best though?? (I mean, good, without being overly expensive? )
Old Mar 31, 2005 | 09:29 PM
thelastz28's Avatar
Re: Break Problems
What causes the rotors to warp in the first place? This wont happen with aftermarket? Thanks Capn.
Old Mar 31, 2005 | 09:37 PM
alburst's Avatar
Re: Break Problems
The warpage is usually caused by high levels of heat and friction causing the rotors to lose thier shape. It all depends on which aftermarket brand you decide to go with, I would suggest just replacing the rotor(s) with GM OEM Replacments because I have seen TOO many cracked aftermarket cross-drilled rotors. Good Luck!
Old Apr 1, 2005 | 11:52 AM
Re: Break Problems
Moving from "General...." to "Suspension, Chassis and Brakes" forum.
Old Apr 2, 2005 | 07:44 PM
thelastz28's Avatar
Re: Break Problems
Is my problem in the front rotors of the back? Thanks guys.
Old Apr 3, 2005 | 08:38 PM
Shempy's Avatar
Re: Break Problems
1) To clarify, a brake is a stopping mechanism whereas a break is a pause or a split.
2) Good chance it's your rotors as already mentioned
3) GM replacements are a bad choice
4) drilled are a bad choice
5) one of the best replacements are Brembo rotors, available at Tire Rack among many other places
6) It's probably the fronts since that's where the most heat is generated
7) It's not a permanent fix, but you can have your current rotors checked and "turned" at a brake shop to machine them flat again. If you're tight on cash, no sense in buying new rotors until you're sure it's warped rotors causing your problems.
Old Apr 4, 2005 | 12:09 AM
respectirocz's Avatar
Re: Break Problems
check the balance on your tires
its very stupid, but its very possible a shimmy is the problem
a weight could have fallen off or if u drive like me, your tires are bald and the natural imperfections in the tire that brough the weight are no longer there, again resulting in an imbalance
Old Apr 9, 2005 | 09:15 PM
thelastz28's Avatar
Re: Break Problems
Problem fixed it was my front rotors, they were warped. I had them machined. The steering wheel problem is fixed. Thanks for your help guys.
Old Apr 9, 2005 | 09:22 PM
Re: Break Problems
np, by the way your city is my last name lol im gonna have to go there one day
Old Apr 9, 2005 | 09:50 PM
thelastz28's Avatar
Re: Break Problems
Nice last name 97s10onDubs. The city is not all that great. Thanks for the help, though.
Victor Lamb
Aug 26, 2017 02:52 PM
blkWidow
Sep 6, 2015 05:17 PM
grabbem88
Feb 13, 2015 03:09 PM
1LEThumper
Jul 14, 2003 12:45 PM
