E-Brake?
Old Mar 17, 2005 | 10:44 AM
Pabz2k1's Avatar
E-Brake?
When ever I pull the E-brake up the Brake light doesn't come on. Also when I start up the car the Headlights just turn on even with the brake up. It's like the car doesn't even sense the E-Brake... Any thoughts on what could be causing this?
Old Mar 17, 2005 | 10:50 AM
rncotton's Avatar
Re: E-Brake?
Ever spill a drink in your console?
Pull the center console and take a look at the brake switch. You'll see it at the base of the handle. If it's gunked up, you can clean it with alcohol or "tech spray".
If that doesn't fix it, replace the switch.
Old Mar 17, 2005 | 11:09 AM
Re: E-Brake?
Might want to mention what year your car is.... all F-Bodys are not the same.
Old Mar 17, 2005 | 04:10 PM
Pabz2k1's Avatar
Re: E-Brake?
Oh my fault, It's a 2001 V6 Camaro
Old Mar 17, 2005 | 04:42 PM
Pabz2k1's Avatar
Re: E-Brake?
Problem solved. Turns out the switch was gunky. Thanks rncotton
BoobSter-lt1-z
Feb 7, 2004 03:50 AM
Ferocity02
Sep 11, 2003 02:37 PM
ERIK93Z
Sep 4, 2003 06:06 PM
ERIK93Z
Sep 3, 2003 01:33 AM
ip305
Mar 6, 2003 04:57 AM
