DFI What do you think??
What do people think of DFI. What are the pro's/con's of DFI in a daily driven "street car"..Boost Fbody.
looking into the Gen7, what do people think of it.
Any input would be great..
thx
thx
Re: DFI What do you think??
I have it and love it. Its a very nice system, you can smoth out 3D graphs for a better drivability then Lt1 edit. Good luck and make sure you get someone that really knows how to tune with one.
thx
thx
I have it. I really like it. Makes tuning a breeze. 2 seconds to switch between race program and street program. Also be sure to get DFI version 4.0. It has a few new features that are going to make driveability much better. The biggest is the PE (Power Enrichment) function. Essentialy you can set your AF table to whatever you want say 14-1 then at a set % of throttle opening it will automatically switch to a richer AF like 12.8-1 or what ever you want.
Originally Posted by EDS Z28
What can it do for driveability?
And, what is the best size injectors to run on the steet, 75's?
As far as injector sizes, opinions will vary. I run 48lb Accel units and have had good luck with them. Job Spetter from TurboPeople tuned my car initially and he said they are almost maxed at top end but unless I add more boost they are perfectly sufficient.
Do you drive your car every day or close to it, do you think you need a MAF sensor..how is the driving around, start up , cold start, ...
A DFI system will allow you to tune your car on and offline and is easily tunable. A lot depends on your mods to your car. They can be installed with a piggy back harness which keeps your PCM in place allowing for full dash functionality. Also the stock PCM takes care of transmission functions leaving fueling strategy to the DFI box. You can do the same thing with a FAST box, but the DFI has much more advanced control strategys.
Jesse_Boyer
Jun 12, 2003 09:26 AM
