Tire rub
Old Oct 14, 2004 | 11:37 AM
FlyboyZ28's Avatar
Tire rub
i have 11" zr1's on the back and the fender lips are rubbing and cutting into the sidewall a little. Is this more of a cosmetic thing or is it somthing I'm going to seriously worry about. I need to roll the lips i think, but i dont know the best way to do it. any help is apprecitated
thanks
Dan
Old Oct 14, 2004 | 11:52 AM
BlownF1's Avatar
Re: Tire rub
I think it's a combination of things in your signature. I'm running AFS 17x11's with 315/35-17's and Eibach's also...have you had the rear end re-centered? Is it only the passenger side that rubs? If so, you need an adjustable panhard bar (I have the Unbalanced Engineering one - it's a nice piece!) and you should also install the GM jounce bumper spacers to limit the rear-end travel if you haven't already. I just had the rear of mine centered on Monday and no more rubbing so far. I have not needed to roll the fender lips yet. When you lower the car, the rear end moves to the passenger side. I hope this helps...good luck,
Old Oct 14, 2004 | 12:10 PM
FlyboyZ28's Avatar
Re: Tire rub
It does rub more on the passenger side than the driver, but i am getting rub on both sides.
Old Oct 14, 2004 | 01:15 PM
Re: Tire rub
What offset are the wheels? Sounds like you have 36.5 ZR1 offset, rather than the 50mm GS offset.
Old Oct 14, 2004 | 05:50 PM
FlyboyZ28's Avatar
Re: Tire rub
They are the 50mm. At least that is what they said when i bought them.
Old Oct 19, 2004 | 12:30 PM
BlownF1's Avatar
Re: Tire rub
Did you pound in the forward part of the wheel wells down near the lower control arm? Are you running the GM jounce bumper spacers? Those two things will go along way to solving the issue, then you need to re-center the rear. Gotta do those 3 first...
Old Oct 19, 2004 | 06:49 PM
FlyboyZ28's Avatar
Re: Tire rub
Arent the GM jounce bumper spacers only needed if its rubbing on the inside sidewall. I have problems with it rubbing the outside.
Old Oct 19, 2004 | 07:03 PM
BlownF1's Avatar
Re: Tire rub
They limit the rear end travel, so depending on where your's rub it may alleviate some of it. Mine were rubbing in several places and I'd estimate the jounce bumpers solved about 40% of it initially, the inner pounding another 30% and re-centering about 25%...and I only get it now over very harsh transitions, and even then it's really minor and quick. I have not rolled the edges, nor do I plan to.
Old Jan 25, 2005 | 06:29 AM
max929's Avatar
Re: Tire rub
My bounce spacer on the right needs replacement: would local auto parts store have them? Or do I have to go to the dealer?
Old Apr 15, 2005 | 06:57 PM
TMorgan800's Avatar
Re: Tire rub
I have an adjustable panhard rod..(BMR) .. which way to I turn the adjusty thingy??
I have never adjusted it... and my tire rubs on the passenger-outer-fenderwell..
Rotate away from me.. when looking at the rear or Rotate Toward me??
I know. its a silly question.
--Troy
Old Apr 15, 2005 | 11:38 PM
Re: Tire rub
Since the PHR bolts to the drivers side of the axle assembly, lengthening the rod will move the body toward the right (passenger side). That would increase the clearance between the outside edge of the passenger side tire, and the inner edge of the passenger side fender lip. You need to measure before you start, so you know how far you moved it, and can verify that you moved it in the right direction. Which way you need to rotate the bar depends on whether it is single or double adjustable, and which end they put which threads on. You should be able to just look at the threads on the ends, and figure out which way to rotate the bar to make it longer.
2QUIK6
Sep 17, 2016 02:31 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
colts0455
13
Aug 7, 2015 09:15 PM
Slayer
Jul 4, 2015 03:06 PM
