15x9 Draglites....what size backspacing??
Old Apr 15, 2005 | 09:35 AM
DB75's Avatar
If we need 5.5 b.s. for a 15x8 wheel and 7.5 b.s. for 15x10 then would it be safe to say I need 6 or 6.5 b.s. for a 15x9?? Just wondering if anybody has experience with running a 15x9 setup on the rear.
Old Apr 15, 2005 | 11:40 AM
DB75's Avatar
Re: 15x9 Draglites....what size backspacing??
Just checked summit's website. Weld doesn't make a 15x9 draglite with the 6 or 6.5 backspacing. Guess I'll stick with the 8 or 10'', later.
Old Apr 15, 2005 | 11:56 AM
You need to ask Weld what they make. Summit does not list all the possible sizes. I know when I bought my 15x10 7.5" BS from Summit, I had to go to the Weld website and get the part # for the wheel, then call Summit and talk to a rep to place a "special order". They did not list, or stock the 7.5" BS wheels.
The "problem" is that Weld has "improved" their website to the point where it is now virtually useless. You have to be clairvoyent to even figure out where on the website they even list the Pro-Stars, and then when you find them there is not tech info, no measurements and no part numbers.... just a place to click and order a wheel. You will probably have to e-mail them to find out if they make what you want.
Hint:
Go to Weld Industries website.
http://www.weldracing.com/
Click on the "Weld Racing" icon, which shows the photo of a 4x4
When the "2004 Forged" screen pops up, click on "Wheels" on the top bar
When a screen shows up showing what appear to be mainly truck wheels, look for the icons immediately above the wheels photos, and click on "Sport Forged".
You should now be at the Draglite/Pro-Star/Rodlite page........
Ridiculous!
Old Apr 15, 2005 | 12:33 PM
DB75's Avatar
Thanks, Injuneer. I know what you mean about Weld's website. I checked it out 3 or 4 weeks ago and was completely dissappointed. Summit must have updated their site recently. They listed 5.5 b.s. for the 8'' and 7.5 b.s for the 10'' wheels. This was for prostars and draglites. Their wheel and tire section is pretty thorough now. One last question if you don't mind. Is a 275/50/15 drag radial too big for a 15x8?? Thanks again.
Old Apr 15, 2005 | 11:43 PM
BFG recommends that you use a wheel width of 7.5" - 9.5" for their 275/50-15. So an 8" wide wheel is fine. If you are using a different brand, check the manufacturer's specs.
Fred
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
