4l60E 3rd gear slips (or fourth, not sure) when at WOT
Old Apr 1, 2004 | 01:35 AM
Pasky's Avatar
My cousin has a 00 Trans am (Non-ws6) with a auto 4l60E. It will shift fine in normal driving conditions. However, when he guns it at WOT the transmission will slip between 2nd and 3rd or 3rd to 4th (Im clueless on autos, I own manual vehicles). We tried some Lucas Oil Stop Slip and that helped a little, anything else we can try (TV Cable?) Before taking it to be diagnosed? Thanks.
Old Apr 1, 2004 | 07:15 PM
Pasky's Avatar
More auto guys than manuals and none of you had a slipping problem ?
Old Apr 1, 2004 | 07:59 PM
ABA383's Avatar
Just had the same thing happen to my 95....time for a rebuild...sorry...
--Alan
Old Apr 1, 2004 | 11:55 PM
Terran2k's Avatar
I have a similar thing, Im lucky if it'll shift into 4th at WOT anymore. I just take it easy on her for now, until i can afford a rebuild.
Old Apr 2, 2004 | 12:08 PM
94ZRiCeKiLr's Avatar
its more than likely 3rd....4th wont engage at WOT until like 130+ mph....
Old Apr 2, 2004 | 03:00 PM
Pasky's Avatar
So the clutches are bad? Fluid needs a change? Maybe the TV cable? I mean, whats the problem?
Old Apr 2, 2004 | 05:50 PM
Lisa33's Avatar
There is no TV cable on 94-> . Dont no if a fluid change will help. (dont think so). If the clutches are bad tha onlu things gona help you for the moment is raising the oil pressure for faster/harder wot shift (reprogram the pcm) That is only a temporary solution...... sorry to say you gona need a rebuild soon....(my opinon)
Old Apr 2, 2004 | 09:10 PM
i second that....if it's slipping, anything u do is a temporary fix....slippage = inevitable rebuild.
Old Apr 3, 2004 | 10:46 AM
12SCNDZ's Avatar
Yup...The 3-4 clutches are smoked. There's quite a few things we do to them when we rebuild them to prevent it from happening in the future.
4L60E's are more than capable of handling times into the 10 second zone if built properly.
Frank
All-Trans Transmissions
Keenan
Jan 19, 2023 12:24 PM
ChrisFrez
Mar 8, 2015 01:22 PM
jackpawt883
Feb 26, 2015 09:04 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
taner
Aug 14, 2002 10:10 PM
