M21 or M20?
Old Dec 9, 2003 | 11:56 PM
RB97Z28's Avatar
M21 or M20?
Besides the Z, I also have a 57 Chevy. I'm going to be replacing the transmission with a muncie 4 speed but I'm not sure which set of ratios would be best--close or wide. The car will be street drivien with a 373 or 411 rear. Can anyone give me a suggestion? Thanks.
Old Dec 10, 2003 | 12:55 AM
90rocz's Avatar
My dad's '68 SS396 Camaro had an M22 and 3.73's, and he could lift the front tires 1st and 2nd!...clutches didn't live too long tho..
Old Dec 12, 2003 | 08:16 PM
RB97Z28's Avatar
Thanks. With M22's and M21's having the same gear ratios(called close ratio) I guess what your saying then is that in a heavy stock 57 Chevy with 373 or 411 rear gears and a potent small block that close ratio and not wide ratio is the way to go. I thank you for the opinion. I need more info though. Can anyone else offer a suggestion?
Old Dec 13, 2003 | 06:20 AM
rskrause's Avatar
Moderator
The narrower and higher the powerband, the closer the ratios should be. The higher first gear is the problem with close ratio though, but using a lower rear end gear will help. So, probably close ratio with the 4.11's. But some more info will help. How big a cam do you plan to run and what size are your intake ports?
Rich Krause
Old Dec 14, 2003 | 12:27 AM
CamanZZ4's Avatar
I think I may be able to help you here!! I have one of each!! I have a 69 Camaro with a m20 and a 3:73 rearend. My dad has a 69 Camaro with an M21 with a 4:10 rearend. Dads car has a crate ZZ1 engine and my car has a crate ZZ4. Almost identical setups. Even though we have never "officially" raced, we have had our fun on the street. In all honesty, between the 2 ratios, you cant feel much difference. Although, his car does feel stronger taking off. Going down the freeway doing 60, dad is running at 3000rpm and I am running at 2600. Hope this helps you some!!
Adam
bandit's77
Jul 31, 2005 12:41 PM
wickdracer
Classic Engine Tech
Apr 13, 2005 11:24 PM
stale
Jan 12, 2005 10:11 AM
1quick7
Classic Engine Tech
Jan 22, 2004 01:44 PM
kissel
Classic Engine Tech
Dec 22, 2002 10:30 AM
