what size tranny cooler do I get??
Old Jun 3, 2003 | 09:24 AM
john-e-boy's Avatar
I have a 92 RS with a 350 TPI and a 700R4 in it, what tranny cooler do I get for it? My options are
12 X 7 1/2 X 3/4
15 1/2 X 10 X 3/4
Just want to make sure which ever one I get fits
John
Old Jun 3, 2003 | 09:37 AM
aklim's Avatar
I'd go for the larger of the 2 if I could stuff it in.
Old Jun 3, 2003 | 06:22 PM
Sitting Bull's Avatar
Usually, the cooler is rated by the gross vehicle weight the cooler can handle. I find that my 12,000 lb. gvw cooler is quite sufficient for the 86 Camaro.
TheGreatJ's Avatar
That's probably more cooler than you need. The 12x7 will be plenty (unless you like to tow your Camaro to the track with your other Camaro) and the larger one will just obstruct airflow to the radiator.
Old Jun 3, 2003 | 10:02 PM
Nitromethane's Avatar
I use a small one on my IROC cuz it was free, but as long as you have that air dam in tact under the radiator, you can run the big one, especially if you wanna run a higher stall converter - number 1 failure for tranny's is heat.
dylan1303
May 22, 2015 12:24 PM
RedLineRev
Jan 23, 2003 03:51 PM
Dragonballz28
Sep 10, 2002 01:45 PM
Javier97Z28
Sep 8, 2002 07:23 AM
Cam95aro
Sep 1, 2001 10:35 PM
