Fuel Problem
Old 03-25-2009, 06:15 PM
sobo's Avatar
Fuel Problem
Hi Guys,
305 tpi. If I start the car with my foot in the gas it will start and run. When I let my foot off the gas it dies.
Give my your opinions.
Thanks,
Sobo
sobo is offline
Old 03-27-2009, 08:51 PM
86camaro383's Avatar
doesnt sound like a fuel problem, sounds like a idleing problem.
86camaro383 is offline
Old 03-27-2009, 09:23 PM
sobo's Avatar
After goofing with it today, I think I have a vacuum leak. I'm stupid when it comes to the vacuum system. I had a hose with a check valve coming from my intake to the front driver side of car disappearing under a canister. What is this? Sorry for my dumb question as I never toy with the vacuum.
sobo is offline
Old 04-02-2009, 05:40 PM
Rice Killer87's Avatar
Thats a vacuum canister....it just stores vacuum for the car b/c many things on those cars use vacuum to operate...like the brakes, and all the HVAC controls.
Vacuum leak is probable, lots of lines to dry out and crack.
Could also be a stuck open EGR valve. Thats the goldish looking circle thing on top of the base plenum...put you hand in there and underneath it through a hole in it...you'll feel a 'bottom' to it, try to push that up and see if it comes back down. If it doesnt move, you need to somehow get it to move.
If thats stuck open, the car wont idle.
Rice Killer87 is offline
DirtyDaveW
12-01-2016 05:37 PM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Scottyboy
02-11-2015 10:28 PM
97Z28Muscle
02-06-2015 10:44 PM
Quick Reply: Fuel Problem
