Will these wheels fit?
Old Apr 14, 2004 | 08:07 AM
Jono's Avatar
Will these wheels fit my car? They are 18x10, with a 41mm offset and a 7 1/8" backspace. I did a search and read that with 18x10's I should get a 50mm offset and 7.5" backspace, but I really like these wheels and I'm hoping they will fit properly. Here's a link for them, they're American Racing wheels.
Oh, and for the front I would get the 18x9's wth a 25mm offset and 6" backspace, so I'm also wondering if these will work.
Old Apr 14, 2004 | 11:04 AM
leadfoot94's Avatar
Wrong Forum...Try the wheels and tires forum.
Old Apr 14, 2004 | 11:59 AM
18x10:
Depends how close you want the outer edge of the wheel/tire to be to the outside of the fender. The typical 17x11 50mm ZR1/GS wheel (see photo linked below) places the outer edge of the tire just under the outer top edge of the fender when you look straight down from above. A 41mm offset on a 10" wide wheel will sit inside the fender approx 1/10th inch further than that wheel. A 50mm offset will put the tire about 1/2" further into the fender than the ZR1/GS.
18x9:
Assume you are looking at these for the front. A 25mm offset will probably put the outer edge of the wheel/tire outside the front fender..... that is a 4.0" "frontspace", and that means it will stick out one inch more than the front wheel in the photo below (ZR1 17x9.5 56mm offset):
http://cjcfo.fbody.com/members/injun...C/Rr34Dr02.jpg
I don't think you want to go any less than 38mm offset on a 9" wide wheel. Compare to a TT II 17x9.5" 44mm offset. That has a 3.5" frontspace, as would a 9" wide wheel with 38mm offset.
Old Apr 14, 2004 | 09:11 PM
Jono's Avatar
Thanks for the help. I guess I'll have to look for different wheels, I don't want them stiking out past the body.
mschmidt33
Mar 15, 2015 07:20 PM
Moshbmx1
Jan 20, 2015 03:27 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
Dec 4, 2014 11:56 AM
