Will these Fit.
Old Oct 31, 2005 | 08:11 AM
cwaldt's Avatar
Will these Fit.
I know 17x11 will fit on the rear with the right offset I just didn't know if thos 12" wide rears would fit under there. Anybody know.
18x9.5" & 19x12 C6-ZO6 Wheels
# Fits 2006 Chevy Corvette
# $1150/set, A+
# 18x9.5 Front and 19x12 Rear Chrome wheels
# 5x4.75" lug diameter
# +50mm/+59mm offset
# Center caps included
# O.E. Reproduction
http://www.lakeshorewheelandtire.com/wheels/5350-c.JPG
Old Oct 31, 2005 | 08:53 AM
Re: Will these Fit.
A 12" wide wheel with a 59mm offset calculates to about an 8-3/4"+ backspace. That would put the inner edge of the tire up against the LCA's and require that the inner fender liner and the subframe behind it be move over about 1/2" (mini-tubbed). You can gain a little clearance on the LCA's with a tubular LCA with rod ends and offset spacers to move them inwards in the factory mounting brackets.
This is the room available with a 7.93" backspace.... the 12" wheel would be in another 0.8".
Looking straight up from below, after hammering the inner fender liners:
http://cjcfo.fbody.com/members/injun...C/TirClr5R.jpg
Looking from behind:
http://cjcfo.fbody.com/members/injun...C/TirClr2L.jpg
Devinfoote87
Sep 4, 2015 05:52 PM
TGGodfrey
Aug 17, 2015 08:43 PM
Jul 10, 2015 02:23 PM
Z4Ccoupe
Jun 16, 2015 01:13 PM
13qtr
Jun 9, 2015 03:30 PM
