Will 15" Wheels Fit/What is the Bolt Pattern?
Hey guys a friend of mine gave me a set of MT Et Streets 26X10.5X15 free with 3 runs on them and i am now looking for wheels. I think they will fit but i don't know for sure because i have 18s on the car now. Also i am looking around here at places for something cheap but is the bolt pattern 5*4.75 like most chevys? thnx guys in advance.
Re: Will 15" Wheels Fit/What is the Bolt Pattern?
3rd and 4th Gen F-Bodies have a 5 X 4.75" (120.65mm) bolt circle.
There are at least two 15" wheels that will fit without any interferences.... The CenterLine Telstar (only available in 15x8" with the correct 5.5" backspace), or the Bogart Billet P1 (available in a 4th Gen specific 15x9.5" with the correct backspace to keep the tire under the fender). That covers a range of about $100 per wheel to over $300 per wheel.
You could also get Weld Pro-Stars or Draglites, both of which come in 15x8 5.5" BS or 15x10 7.5" BS, but require grinding down the rear brake calipers to fit.
The wheels would have to be like 15x8 or so that it would be good for my tires but where can i get these and how much are they...? Wouldn't like a cragar ss wheel or a rally wheel from a older corvette? just wondering i am new to the camaro ownership lol
Like Fred said above....The only wheels that will fit w/o mods and look decent are the 15x8 Centerline Telstars with the 5.5" backspace and the Bogarts which are $$$$. I think the Telstars are around $130/each. The only other option is the Centerline Convo Pro in the 15x8.5 with a 5" backspace. These will fit with no mods and are lighter than the Telstars, but they will hang the tire out just slightly with an ET Street...more so with a radial because of the sidewall buldge. They run $175ish/each.
The issue with 4th gens is the large backspace required to tuck the wheels under the car.
--Alan
--Alan
stockssn2o
May 25, 2015 08:54 AM
