Widest Rear Tires On A 7.5 Rim
Old 05-14-2007, 03:53 PM
THE_RUCKUS's Avatar
i have some serious issues hooking up. what are the widest tires I can fit on a 7.5 rim on a 94 z? possibly a 265? wider would be sweet.
any opinions?
THE_RUCKUS is offline
Old 05-14-2007, 04:02 PM
J96Z's Avatar
245 maybe? I woould hope you have problems hooking up with such a narrow wheel. Ebay is a good place for cheap 17x9 wheels.
J96Z is offline
Old 05-14-2007, 04:37 PM
You have to specify the diameter of the wheel as well..... what section width tire fits correctly on a 15x7.5" wheel is going to be different than what you can fit on an 18x7.5" wheel. It would also depend on the aspect ratio of the tire you are considering.... eg - 245/50-16, 255/40-18, etc.
Injuneer is offline
Old 05-15-2007, 12:30 AM
THE_RUCKUS's Avatar
16x7.5
I don't think I would have much of a problem fitting my 245/50's on there, but I'd like to see if I could squeeze at least a 265
Old 05-15-2007, 12:05 PM
CamaroRacing12's Avatar
dude go buy some used 17x10's or somethin
CamaroRacing12 is offline
Old 05-15-2007, 03:27 PM
Greed4Speed's Avatar
Better yet.....Just buy some softer compound tires and do the relavent suspension mods.
17's won't help you. A shorter side wall is giong to decrease traction more than the wider tread patch will increase it.
Greed4Speed is offline
Old 05-15-2007, 05:11 PM
You aren't going to find a decent "high performance" tire wider than 255 in a 16" diameter. 255/50-16 will work on wheels 7" - 9" wide. I saw someone claiming he found a 265 drag radial somewhere, to is might be worth some research.
Injuneer is offline
mongoose=
03-22-2015 07:22 AM
mschmidt33
03-15-2015 07:20 PM
cristian1311
03-04-2015 04:45 PM
Jason Short
01-19-2015 06:33 PM
siguy
11-27-2014 10:07 AM
Quick Reply: Widest Rear Tires On A 7.5 Rim
