What psi am i supposed to go to?
Old Oct 30, 2005 | 01:57 AM
pHEnomIC's Avatar
I have gforce kdsw's that say max 44psi. I was wondering what psi i should go to cold. I usually do 35psi. My gas mileage is like 13-14mpg so im looking to improve something here. Ive heard somewhere that you should go to the max on cold.
So would like 41psi be a better choice than 35 at least for the rear wheels or should i got 44?
Old Oct 30, 2005 | 09:25 AM
Re: What psi am i supposed to go to?
What size are the tires? How do they compare to the tire size that was used for the tire pressure label on the door edge?
The "max 44psi" value is the pressure required for the tire to achieve its maximum load carrying capacity. The typical wide tire sizes used on 4th Gens are loaded nowhere near maximum load. Hence, you do not need 44psi, and should not use 44psi. That will bulge out the center of the tread and cause the center of tread to wear excessively fast. Definitely reduce traction. Might save you fuel mileage, but you'd spend the money you saved replacing the tires.
If your car had the Z-rated tires on it from the factory, it will have a label recommending 35psi for maximum speed rating.
With the stock tire sizes (245/50-16) I had good results with 34-36psi. With wider tires, you may see better results with slightly lower pressures.... with 275/40-17's I ran anywhere from 32-36psi, and with the 315/35-17 drag radials 30-32psi.
Old Oct 30, 2005 | 10:53 AM
pHEnomIC's Avatar
Ueah i got 245s, so then ive been doing a good jon keeping them at 35 then. Thx for verifying. I can't complain, good feel, no uneven wear, good traction.
KYWes
Jun 14, 2022 06:52 AM
13qtr
Oct 28, 2016 08:11 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
