What is the best size tire for 17x11 rim
Old Sep 14, 2006 | 07:06 PM
Lt1 and Ls1's Avatar
Would a 275 40 17 go on it ok? Or do you need 315s
Old Sep 15, 2006 | 08:54 AM
Re: What is the best size tire for 17x11 rim
Check the FAQ.... most tire manufacturer's will accept wheel widths from 9.0" - 11.0" for a 275/40-17. Whether its the "best" choice, or even looks good is sort of subjective. I'd guess 99% of the people with 17x11 wheels run a 315/35.
Old Sep 15, 2006 | 09:09 AM
gt_biker13's Avatar
275s will work but they really look stretched, IMO theres no point in getting wider wheels if youre not going to put wider tires on. If you want 275s then get 9.5" wheels all round.
Old Sep 15, 2006 | 12:02 PM
Coolformula's Avatar
If you dont' want bigger tires run the smaller tire and lighter wheels...
Old Sep 15, 2006 | 12:53 PM
That wasnt my issue, just the fact that my tires are still really good, and was wanting to be able to use them, but if they wont work or look good I will just by new tires
Old Sep 15, 2006 | 01:09 PM
Just go look on tirerack to see if your tire size will fit on a 11 inch rim. If it does I would just use them until you wear them out.
Old Sep 15, 2006 | 01:16 PM
Ok thanks for the advice
Old Sep 15, 2006 | 01:43 PM
That's where the info in the FAQ came from. Some manufacturers or specific tire lines may vary a bit, but the data in the FAQ covers 90% of the cases.
315 on an 11" wide wheel, compared to a 275 on a 9.5" wide wheel.
Old Sep 15, 2006 | 03:09 PM
It said it would but I think it would look stupid. Thanks for the pic of the side by side comparison
HectorM52
Jul 30, 2017 11:46 AM
mschmidt33
Mar 15, 2015 07:20 PM
cristian1311
Mar 4, 2015 04:45 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
