upgrading wheels, lets hear some suggestions?
Old Jun 11, 2010 | 12:23 AM
InTeNsE's Avatar
I'm upgrading from my stock wheels on my 2002 black z28...
I was thinking about getting some chrome OEM c6 corvette z06 wheels. Will 19s on the back and 18s on the front fit on a camaro or do I need to do 18s all around?
some others i've thought about possibly getting...
Smoothie II
Torque Thrust II's
lets hear some more suggestions
thanks much
Old Jun 11, 2010 | 11:50 AM
C6 Z06 OEM wheels:
Front: 18x9.5" 40mm offset - This is going to fit in the front of a 4th Gen, but the outside edge of the tire is going to possibly be outside the fender, and you will have problems with the tire rubbing in the plastic fender liner when you turn the steering wheels.
Rear: 19x12.0" 59mm offset - This will require about a 3/4" to 1" spacer to move the inside edge of the tire away from the inner fender and the LCA. With that spacer, the outside edge of the tire will be about 1" outside the fender.
Old Jun 11, 2010 | 01:12 PM
InTeNsE's Avatar
I don't want any sort of rubbing problems but I really love those wheels, what would be the best way to go about doing it? Just go with an 18 back 17 front or 18 all around combo and get the correct tires that will not cause any rubbing?
Old Jun 11, 2010 | 02:16 PM
benhart21's Avatar
It's not the diameter that you should be worried about there. That width and offset are what would cause the problems. The appropriate measurements can be found in the stickies at the top of this forum.
Old Jun 11, 2010 | 04:38 PM
There is a post in the "Wheels and Tires FAQ - General" that covers the wheel width vs. wheel offset. That is what determines whether the wheel/tire sits in the wheel well correctly. Too much (positive) offset, and the inside edge of the tires hits the inner fender. Too little offset and the wheel/tire is outside the fender, or directly under the fender lip. You have to look at the combination of the wheel width and the offset to determine this. That's why there is a post in the "sticky".... to offer guidelines.
As noted in the post above, the wheel diameter is relatively unimportant. You put a tire on the wheel so that the outside diameter of the new tire is close to the diameter of the stock tires. This is also covered in a post in the Wheel and Tire FAQ - General.
Old Jun 12, 2010 | 11:56 AM
bluz28's Avatar
IMO, the BC Smoothie II's would look the best!
17 x 10s, F & R :
http://i136.photobucket.com/albums/q...S/DSC00369.jpg
http://i136.photobucket.com/albums/q...S/DSC00357.jpg
Old Jun 12, 2010 | 12:34 PM
benhart21's Avatar
I'm not normally a fan of that design of wheel, but that looks quite good. I'm quite partial to my Y2K C5 Vette replicas, but I also really like the new style of the ZR-1s. The nice thing about replicas over the OEM wheels is that you can get them in the proper F-body offsets and not run into the problems that Injuneer explained above.
Old Jun 13, 2010 | 12:48 AM
deerslayinrenek's Avatar
I went with C6 Z06 Replicas and I love them
Old Jun 13, 2010 | 08:23 PM
Klypto's Avatar
y2k wheels. love them. 17x8.5 front, 18x9.5 rear
255/40/17 275/35/18 tires
EDIT: Name:  backtothefuture.jpg
back to the future wheels is cool too!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
92ragtop
Dec 27, 2014 01:56 PM
