rim question?
Old May 25, 2005 | 06:42 PM
black02z28's Avatar
rim question?
does anyone know if 18 inch rims will fit on my 02 z28 i,m looking for black chrome rims where can I find them anyone? thank you.
Old May 25, 2005 | 11:25 PM
Re: rim question?
There are people running 20's on the 4th Gens, so you shouldn't have any problems with an 18" wheel. You will need to insure the bolt circle is correct, and that the offest/backspace for the specific rim width is correct. Then you will need to select a tire with an outside diameter which is a close match to your stock tire diameter.
Old May 26, 2005 | 09:28 PM
Schmidt519's Avatar
Re: rim question?
I went with the Z06 18's; 9.5 in the front, 10.5 in the rear, had no issues with them fitting. Initially I went with 275 tires on the rear rims, then went up to 305 drag radials, had a minor clearance issue with them, nothing a hammer and 10mins couldn't fix though. As long as you stay 295 and under in the rear, you'll be fine.
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
siguy
Nov 27, 2014 10:07 AM
