Help with open-ended lugnuts
Old Apr 1, 2008 | 04:45 PM
nb 96 z's Avatar
I've got longer wheel studs in the rears and I have zr1's for the street, and the studs are too long for the lug nuts. Is there a certain type of open-lug nut that I would need to run with the zr1's? Thanks.
Old Apr 1, 2008 | 07:31 PM
FivePoint7z28's Avatar
12X1.5 open end acorn seat.
Old Apr 2, 2008 | 02:47 PM
I have the 17x11 ZR1's in the back, 3" x 1/2-20 studs. I got a set of closed end "duplex" acorn lugs (at least twice as long as the standard acorn), and they were still not long enough. So I drilled/tapped the ends so the tips of the studs would fit through them. Doesn't look great, but at least there are no ugly threads sticking out of the end of the lugs.
The duplex lugs were made by Excaliber. I'm not sure if they make them in 12mm-1.5.
97FormulaWS-6
Wheels and Tires
Apr 21, 2004 07:19 PM
RED95LT1Z28
Mar 29, 2004 01:18 AM
Need4Camaro
V6 Tech
Mar 1, 2004 06:42 PM
BlackLT1_TX
Dec 13, 2003 01:49 AM
Curt (pres AAMC & ZAA)
Feb 8, 2003 08:19 PM
