Fitment on 3rd gen (84)
Old Feb 23, 2014 | 10:32 AM
bds001's Avatar
Trying to find out if 18x8 +48 wheels would fit on a 3rd gen. Any help would be very appreciated!!
Old Feb 23, 2014 | 11:02 AM
Re: Fitment on 3rd gen (84)
According to this source,
Billet Wheel Adapter FAQ - Skulte Performance Designs
an 84 runs 0 offset wheels. The 48mm offset would put the wheels almost 2" deeper in the wheel well than the stock wheels. You would need a spacer/adapter to move them back out where they belong.
Old Feb 23, 2014 | 11:18 AM
bds001's Avatar
Thanks injuneer. So long as every thing "fit" would there be any problem to them being deeper in the wheel well? sort of tucked in I guess?
scratch that, read some more of the link. Got a bunch of info. Thanks again
Old Feb 23, 2014 | 12:40 PM
The tires willl probably hit the inner fenders and the lower control arms in the back. The fronts will probably be into the fender liners and the struts. A 3rd Gen owner could give you a more accurate answer whether it can handle wheels with 1.9" added backspace.
But do you really want the wheels and tires tucked that deep inside the wheels wells? Going to look strange.
Old May 22, 2014 | 12:11 AM
ws6transam's Avatar
As I recall, I run a 17 x 10 with zero offset, and a 275-40-ZR17 on all four corners; I ran into clearance issues with the outer tie rod ends which shouldn't be an issue with the larger wheel. I think what you will really have issues with will be clearance when you turn your wheel. You'll rub the tire into the subframe on the front, and into the fenderwell/firewall area on the back. The strut clearance might also be an issue. Details are getting fuzzy, as I did all my research about fourteen years ago =:O though I still have the car (with nicely polished steel where the wheels rub sometimes)
Old Jun 18, 2014 | 07:48 AM
LovSSin's Avatar
personally, i have 17 ' SS mags on my 1992 Camaro and i first bought the skulte 2 inch spacers...but the back stuck out way too much, so they are 1.25 out back and 2 inch spacers up front..perfect fit and drives awesome...18's too big IMHO
asilomar244
Jul 12, 2015 05:53 AM
Jmj93z28
Jul 8, 2015 10:01 PM
Jmj93z28
Jul 8, 2015 06:58 AM
cmsmith
Jul 5, 2015 07:23 PM
camaro02DK
Jul 5, 2015 09:04 AM
