C6 OEM Wheels on a 4th Gen
Old May 3, 2008 | 08:11 PM
  #31
Meister Bill's Avatar
Originally Posted by Steve in Seattle
I don't think there actually IS a "Grade 10" bolt. I may be wrong, but I'm pretty sure SAE bolts and studs are only rated from 1 through 8.
Unless you have aftermarket axles (which typically switch to a 1/2"-20 lug size, in Grade 8), it's likely a metric M12x1.5 stud that snapped. If so, that would be a Class 8.8 stud (about equiv to a Grade 5 in SAE ratings). A 9.8 might have sufficed, but a Class 10.9 metric stud is plenty (no need for a Class 12.9... more maintenance).
I stand corrected. The NAPA studs are the Class 10.9.
Old May 3, 2008 | 09:37 PM
  #32
Steve in Seattle's Avatar
common slip up... but if you goto NAPA asking for Grade 10 studs you may get a blank stare. (just trying to help )
Old May 27, 2008 | 03:08 PM
  #33
Wolves11's Avatar
pcm tune for tires
Have taller tires in back than in front. Fronts are stock height, rears are 1" taller, trips abs inop light. Is there a programmer or a tuner that can reconfig for diff sizes in front and rear. I know hypertech makes one, but it changes for all 4 corners, need to sep front and rear.
Old Jun 30, 2008 | 08:46 AM
  #34
number1's Avatar
I have read the FAQ and done a minor bit of searching. I have been looking at new rims for my 1996 Z28. I wanted 18's all around or 18/19 combo but wanted feedback if anyone has used this type of setup on a lowered camaro before. I have QA1 coilovers and the eibach prokit. I current have ZR-1's with 275/40/17s on all four corners, and I am very sick of that look. Any help would be appreciated.
http://cgi.ebay.com/ebaymotors/19-18...spagenameZWDVW
Old Jul 22, 2008 | 05:17 PM
  #35
HLY_SHFT's Avatar
I use the Doorman studs from O'Reilly's. It was that or Moroso, which they were out of. They have held up plenty well so far.
Old Jul 28, 2008 | 09:02 PM
  #36
mrdillon's Avatar
does anyone have any pics of the chrome as well as aluminum polished C6 rims mounted?
should i go with a 285/35 or 285/40 in the rear?
Old Jul 29, 2008 | 02:07 AM
  #37
96badaSS's Avatar
Helpfull advice
Well, Thanks for the advice guys, I ordered some 5 x 4.75 1.25" thick aluminum adapters on eBay for about $80, and the wheels cleared perfectly and look great! (although I did have to have the hub opening machined about 1/16" bigger to clear the hub, no big deal though) The fronts bolted on perfectly and the car looks awesome with the staggered chrome vette wheels! Next will be adapting C6 brakes (any information on the REAR brake swap would be greatly appreciated!). Thanks again guys for your help!
Old Jul 29, 2008 | 02:11 AM
  #38
96badaSS's Avatar
I have pics of my chrome C6 wheels on my 96 SS, but I can't figure out how to post them here....PM me and I can send them to you.
Old Aug 9, 2008 | 12:22 PM
  #39
You can only post photos by including a link to the photo's location on an internet server. You can not post photos from any other source.
Old Aug 22, 2008 | 07:45 PM
  #40
Cdub's Avatar
Powdercoated C6 wheels
Heres what they look like powdercoated if anybody wants to know. FYI you have to paint the center caps yourself(plastic)!!!
P.S. Does the size of the rear spacer make anybody else nervous????
Old Aug 28, 2008 | 07:24 PM
  #41
wrd1972's Avatar
Here are my 17" x 9.5" chrome C6's with 275/40/17 Cooper 2XS zeon rubba.
Old Sep 6, 2008 | 10:04 AM
  #42
Joe Bellman's Avatar
Old Sep 13, 2008 | 08:41 PM
  #43
BandDirector Blk98ZM6's Avatar
FINALLY, I can post up my pics...I just put them on this morning.
OEM C6 19x10 (79mm offset) rims in SILVER on ALL FOUR corners.
275/30/19 Michelin Pilot Sport A/S tires on all four corners.
1.25" spacers/adapters on all four corners.
Lowered w/Eibach Pro-Kit.
Old Oct 20, 2008 | 11:26 PM
  #44
BabyVetteZ28's Avatar
c6 wheels
i have bought some black C6 ZO6 wheels, the front are 18x8.5 245/40/18 and the rear are 19x10 285/35/19, and i want to install some sportlines eibachs for a good drop, and i was wondering if the wheels would scrape or hit the front or back fenders, i need your help thank you
Old Oct 20, 2008 | 11:38 PM
  #45
c6 zo6
