C5 Z06 Wheels Fit 1994 Z-28?
C4 Z06 Wheels Fit 1994 Z-28?
Was wondering if anyone in the forum knows if Corvette C4 Z06 wheels (17 in front & 18 inch rear) (or is 18 & 19?) (SORRY, DONT KNOW IF 1, 2, OR 3 IN WIDER), will have clearance to fit my 1994 Z-28.
I can get a deal on new chrome. wheels Can't afford to put tires on them for a trial fit. Dealer doesnt know.
thanks
thanks
thanks
thanks
Re: C4 Z06 Wheels Fit 1994 Z-28?
ok, was just checking from the typo. they will fit, u will have to take a file or dremmel and grind down the inner hub on the rear rims tho, thats it.
any recommendation on (affordable) tires?
thanks, you've been a help
just to get the wheel on the hub. im not sure about the tire well clearence, i didnt think about it until u said something, the rear on a 18" zo6 is what 10.5? i think it may go just fine.
Mine fit great with absolutely no problems. I don't know how much your dealer is charging you for wheels, but e-bay can be a great place. Here's a sample of what they have. Not bad for brand new wheels AND tires, ready to go, shipped to your door.
http://cgi.ebay.com/ebaymotors/AFS-4...74583185QQrdZ1
C5 Z06 wheels:
The factory 18x10.5" wheel has a 58mm offset, which puts a really wide tire into the inner fender liner. May require a spacer or a really huge amount of hammering. There are aftermarket 18x9.5" wheels that do not have that problem.
The factory 17x9.5" wheels have a 54mm offset, which is correct for a 4th Gen F-Body.
There is a "Wheels and Tires" forum.... I'll move the post there.
Didn't realize you already had a post on "Wheels and Tires". PLEASE post only on the correct forum. Now I'll try and merge the two threads........
And I changed the "topic" line to "C5" for you.....
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
MissedShift
9
Jul 17, 2002 10:31 PM
