Any other way to change wheel studs?
Old Nov 22, 2004 | 11:59 AM
Huntr1117's Avatar
Is there anyway to change the wheel studs on my car without pulling my whole diff. apart? I have 2 broken wheel studs and I need to change them. My car has traction control with that gear that keeps the studs from being knocked out the backside. Any suggestions?
Old Nov 23, 2004 | 01:44 AM
Huntr1117's Avatar
Re: Any other way to change wheel studs?
ttt
Old Nov 23, 2004 | 04:05 PM
Have you tried a "search"? I'm sure I've seen someone post the "trick" to getting the studs out on the traction control cars, without pulling the axles.
Old Nov 24, 2004 | 12:18 AM
omatter67's Avatar
Just did it myself, Put a deep socket on the other side of the hub and take a hammer and bang them out, there pressed in so just pop them bad boys out the back then put the new one's through from the back put a bunch of washers on the stud and tighten the lug on the stud itself till the studd appears to be fully pressed in. good luck
Old Nov 24, 2004 | 11:57 AM
Huntr1117's Avatar
That doesn't work if you have traction control. There is a gear that stops the stud from comming out the back.
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
