94 Z28 rims on a 2000 Z28
Old May 6, 2007 | 11:10 AM
gsxowner's Avatar
im quite sure there will be no fitment issues between a LT1 camaro rim and a LS1 rim but i was asking to make sure there will be no issues, we are swapping rims b/c i like her's better. both the set of rims are original OEM rims, so is there anything special that must be done or is it a straightforward swap? thanks
Old May 6, 2007 | 11:17 AM
87DJP2001's Avatar
94-2002 Z28 wheels sizes (16/17) are the same. LT1/LS1 are the engine type and have nothing to do with the wheel fitment.
Old May 6, 2007 | 11:26 AM
Dave '97 Z28 M6's Avatar
Late LT1 wheels and LS1 wheels need some minor modification done to the hub area to fit on an early LT1 car.....
But the early wheels fit later cars without issue, so you're OK!
Old May 6, 2007 | 11:27 AM
mdacton's Avatar
I had a friend that had problems using LT1 rims on his LS car.....the center was too small on the rear.......he had to sand it a little but other than that everything was fine
Old May 6, 2007 | 11:38 AM
Hmmmmm... I've only ever heard of the rear hub problem working the other way (late wheels on an early car). But the fix is the same.
Old May 6, 2007 | 11:40 AM
mdacton's Avatar
these were '97 rims going on a '01 car.......it was only on the back also....the front wasd good, But like you said same fix for both.
It was wierd b/c they worked fine on a "98
Old May 6, 2007 | 04:40 PM
pcgamer4life's Avatar
93-96 wheels will fit any 4th gen, 97-02 wheels will fit only 97-02 unless you want to sand out the center of your rim a bit. (In my case, I did.)
Old May 6, 2007 | 04:55 PM
Critter's Avatar
^^^ what he said its also in the facts section in the wheel forum.
looks like you where wrong 87DJP2001 just messing with ya
Old May 7, 2007 | 05:47 PM
Wrong forum... look at the FAQ at the top of the "Wheels and Tires" Forum.
I'll move the post there.
Old May 7, 2007 | 06:50 PM
gsxowner's Avatar
her car is a 94 mine is a 2000, so her rims will fit on my car no problem? or will i have to sand down my hub? and on her car to get it to accept my rims i will have to sand the inside of the rim, do i have this correct?
Deadbolt24
Jan 19, 2015 01:29 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
Hurin
Dec 13, 2014 07:38 PM
bsmith
Aug 23, 2002 04:17 PM
