275/50/16s safe on a 16x8 salad shooter?
Old Jul 24, 2004 | 03:36 PM
96WhiteZ28's Avatar
Someone is selling a set of Hosier tires and he's saying it would fit on a 16x8 salad shooter. I searched the forum and many people say 255 is the biggest safe size for 16x8. Others are saying they run 275 fine. So now i'm confused. I would only run these tires when i go to the track.
Old Jul 24, 2004 | 05:20 PM
Camaro_Maniac63's Avatar
Re: 275/50/16s safe on a 16x8 salad shooter?
You might be able to get them to fit, but it definitely won't be safe. Do not go larger than 255.
Old Jul 24, 2004 | 11:26 PM
Depends.
Hoosier used to make "street" tires, and perhaps they made a 275/50-16. But they stopped making "street" tires, because of the legal issues with the D.O.T. ratings and the high cost of getting the tires certified.
They do make a 275/45-16 in their Sports Car D.O.T. Radial model. Hoosier says those tires will fit properly on wheels ranging in width from 8" - 10.5". The misconception that there is a "255 limit" for 8" wheels arises from the fact that there are no high performance "street" tires wider than 255 available for a 16" wheel. However the 275/45-16 Hoosier Sports Car DOT Radial (not a legal street tire) will fit fine on a 16x8" rim.
Note that a 275/50-16 will be more than an inch larger in diameter than the stock tire.
Might want to check out the Hoosier website to verify the above info.
Item Number - Tire Size - Tread Pattern - Tread Width - Approx. Dia - Circ - Recom. Rim - Measured Rim - * Section Width - A3S04 -Auto Cross
46630 - P275/45ZR-16 - M* - 10.3" - 25.3" - 79.5" - 8.0-10.5" - 9.0" - 11.2" - X -
WARNING
NOT FOR HIGHWAY USE: All Hoosier Racing Tires including DOT labeled Hoosier Racing Tires are designed for racing purposes only on specified racing surfaces and are not to be operated on public roadways. DOT labeled Hoosier Racing Tires meet Department Of Transportation requirements for marking and performance only and are NOT INTENDED FOR HIGHWAY USE. It is unsafe to operate any Hoosier Racing Tire including DOT tires on public roads. The prohibited use of Hoosier Racing Tires on public roadways may result in loss of traction, unexpected loss of vehicle control, or sudden loss of tire pressure, resulting in a vehicle crash and possible injury or death.
Old Jul 25, 2004 | 05:07 AM
MasterEvilAce's Avatar
Wow that last quote is scary... if it's going to give you a loss of traction, etc. etc... who the hell would use them for racing?
Old Jul 25, 2004 | 12:17 PM
Dave '97 Z28 M6's Avatar
They're telling you that you might see a loss of traction on public roads - especially wet ones, no doubt. Drag racing tires really aren't well suited for street use. Among other things, the sidewall flex that they allow (better for launch traction) becomes a liability whenever you go around a corner.
LT14LIFE
Nov 15, 2015 06:22 PM
IndyZman
Oct 22, 2015 02:17 PM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
rideordie
Sep 7, 2015 08:22 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
