255's and 285's
Old Apr 5, 2006 | 12:08 AM
eagleknight97's Avatar
255's and 285's
Who here is running 255/40/17 fronts and 285/40/17 rears on 17x9.5 wheels all around? Also, is it worth it to go with a staggered set up like that, or just go 275's all around? The car will be 95% street driven, with maybe a trip or two to the strip. Im looking at either Eagle F1 GS-D3's or BFG KDW's prolly. I like the idea of the staggered set up so there isnt so much rut following and the steering isnt quite as heavy, but the ability to rotate would be nice also. Plus, would 255's look weird on a 9.5 rim?
Old Apr 5, 2006 | 12:11 AM
Zack's Avatar
Re: 255's and 285's
just do 275's all around. the main reason people go staggard is because wheel widths differ and the wider rear doesnt fit on the fronts...you have the same width, why put different sizes if 275s will fit up front?
Old Apr 5, 2006 | 10:44 AM
Re: 255's and 285's
I responded to this on fbody.com. Wrong size tires in the front.... too small a diameter and too narrow for a 9.5" wide wheel - at least if you picked the correct 245/45-17 size. You want a 255/45-17 at least, in the front.
Old Apr 5, 2006 | 12:32 PM
Re: 255's and 285's
Thats what I said, 255's in front, but yeah, youre right 45 aspect ratio would be correct. I guess this is a moot subject though, ill either be going with 275's all around with 17x9.5 ZR1's or going staggered with C5 Y2k rims.
Old Apr 5, 2006 | 12:59 PM
Re: 255's and 285's
But 255/40-17 is not correct. You need 255/45-17's.
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
Speeds8erM-1
N2O Tech
Oct 15, 2002 05:25 PM
irocz383
3rd Gen / L98 Engine Tech
Jun 15, 2002 01:05 AM
