20"s with 245/35/20 with a 35mm offset
Old Feb 23, 2008 | 01:22 AM
blkgagt94's Avatar
iam gonna be buying some 20x8.5 rims with a 35mm offset for my other car but iam gonna use them on the camaro but iam wondering if i put them on but iam gonna be using a adapter since iam gonna get them in a 5x100 an 5x114.3 so they fit my other two cars. so will the tire be sticking out of the wheel well with a 20x8.5 with a offset of 35mm then with a adapter of 1"
Old Feb 24, 2008 | 11:39 PM
The calculations I did for the table in the Wheels & Tires FAQ (did you check it?) indicate that for an 8.5" wide wheel, a 35mm offset puts the outer edge of the tire close to, but still inside the outer edge of the fender. Adding a 1" spacer would put the tire maybe 1/2" - 3/4" outside the fender. Couple that with the 26.7" tire diameter (larger than stock) and its very likely you will have the front fender coming down on the tread. The back won't be much better.
Old Feb 26, 2008 | 09:48 AM
blkgagt94's Avatar
hey thankx but i got some used 20s dnt know the offset think is like 1/2" in from the fenders an iam gettin the 245/35/20 tires hopefully it dnt rub so i might have to roll them whats the best way to roll them without paint chipping i also got lowering springs on it i heard they go abotu 2" front an back
G-BODYT56
Jan 14, 2022 11:14 PM
96SilverRam
Nov 20, 2016 11:19 AM
Henson071
Dec 30, 2015 09:55 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
gamboa
Nov 11, 2002 12:55 PM
