Texas emissions and safety... HELP
Old Oct 17, 2006 | 07:39 PM
familytruckster's Avatar
Due to work, I'm relocating to the Dallas/Fort Worth area where there is emissions and safety.
I have a 94 caprice wagon that is unlikely to pass either.
Am I screwed? Will I have to remove the drivetrain and swap it in a older vehicle, like a 68-72 chevy pick-up.
I used to drive to the track, put on the slicks and race it and drive home.
We don't have emissions or safety in Grand Rapids Michigan so doing what I did was not a problem.
Here is my motor:
LT1 383 with approx 500 miles
Cast Scat stroker crank
Scat forged H-beam rods
SRP forged flat-top pistons
Total Seal rings gapped for 150 HP nitrous
Std volume high pressure oil pump
Ported aluminum heads
2.00/1.55 stainless valves
CM 612 springs
Aluminum roller rockers
230/236 XE Comp Cam
Cloyes double roller timing chain
Mezzire water pump
S&B air filter
3.5" MAF
BBK 58mm throttle body
Ported intake manifold
SVO 30lb injectors
Walbro 255 fuel pump
No ABS, A/C
Bryan Herter program
Headers
No Cats
The front and rear bumper supports (actual bumper under the plastic) and the inner fenderwells are gone.
Old Oct 17, 2006 | 07:47 PM
ulakovic22's Avatar
Re: Texas emissions and safety... HELP
Don't worry about the safety stuff, you should be ok there. Where in the D/FW area are you moving to. That will decide what your options are.
Old Oct 17, 2006 | 08:14 PM
Grapevine
Old Oct 18, 2006 | 08:52 AM
95GRNZ's Avatar
There are some "friendly" places to inspect your car at.
I've never needed one, so I have no idea where they are at, though. Might want to check with the folks over at LS2.com Texas section or DFWLS1.com.
Good luck!
Old Oct 18, 2006 | 10:17 AM
2QUIK6's Avatar
All you would need is cats and it should pass fine as long as the tune is not way out of whack...at least where I go on the far west side of FTW off hwy 199.
Old Oct 18, 2006 | 10:44 AM
n2ceptor's Avatar
http://www.txdps.state.tx.us/vi/insp...mission+System
2QUIK6
Sep 17, 2016 02:31 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
TitoPR221
May 26, 2015 12:20 AM
readysexgo
V6 Tech
Jul 18, 2002 02:07 PM
