weird problem
Old Dec 2, 2009 | 08:08 AM
CAMBURT's Avatar
weird problem
every couple of weeks i have to add coolant to the radiator. the problem is when the car cools down it doesen't draw coolant back from the recovery tank. i've replace the radiator cap twice already, i can't see any coolant leaking out and the oil seems to be good and not milky which would indicate a possible head gasket leak. it's a 94, 3.4 camaro with 141,000 miles.
any help would be appreciated
thanks
Old Dec 9, 2009 | 03:37 AM
95camaroinok's Avatar
possible water pump or thermostat on the way out.
Old Jan 14, 2010 | 08:09 PM
89 iroc zl1's Avatar
if you replaced a freeze pllug latly then a good nick or scratch on the sidwall could cause a small leak
Old Jan 18, 2010 | 12:54 PM
rsm93z28's Avatar
Have a look here for the problem of "Disappearing Coolant" issues... I suspect a leaking Lower Intake Manifold is the prime suspect:
http://60degreev6.com/forum/f97/disa...ht-miss-t38532
Also...the possible loss point of the replaced Freeze or Core Plugs might also be spot on as mentioned earlier...if you did not use a non-hardening sealer on the lip of the plug when doing the install. See my photobucket for details on Dorman Brass Freeze Plugs for more information:
http://s557.photobucket.com/albums/s...SSFREEZEPLUGS/
Old Jan 23, 2010 | 11:47 PM
ed2552's Avatar
The 3400's are infamous for eating LIM gaskets. It could be leaking into the ports, and not the valley. Does the exhaust smell like coolant?
Old Jan 26, 2010 | 04:24 PM
Sixer-Bird's Avatar
Check the water pump. Mine was doing the same thing, I couldn't figure out what was happening until I noticed tiny drops of coolant leaking from where the water pump bolts up to the block. It was like a mist, so it wasn't that noticable.
Old Aug 23, 2010 | 09:01 PM
geoffreyc1212's Avatar
yeah comes from just under the right bank. you will notice a discoloration where coolant is leaking. there is a weak spot in the pump housing. high temp rtv silicone around the pump gasket is a quick fix. i reccommend a new gasket with a light coat of rtv, and just alittle overtorque on the bolts.
timmy39120
May 8, 2015 11:41 AM
Dylan Latshaw
Mar 21, 2015 09:48 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
