traction control....
Old Apr 30, 2003 | 11:44 AM
  #16
formula79's Avatar
It won't work witout a fuse.....your car is probaly not powerful enough to do one.
Old May 2, 2003 | 12:55 PM
  #17
96fbirdA4's Avatar
If your car had TCS or ASR, you would have a button to turn it on/off right in front of your shifter. My T/A has it.
Check your RPO codes for "NW9" this is the RPO code for Traction Control. The sticker which contains all of your RPO codes will either be in your glove box or on the end of the drivers door.
Old May 12, 2003 | 10:46 PM
  #18
godofdragons's Avatar
my place for the TCS relay has no connections, wtf. i need tcs im the rain :P
Old May 13, 2003 | 08:11 AM
  #19
96fbirdA4's Avatar
Your car doesn't have TCS. Adding some relay to your system will not give you TCS, it doesn't work that way.
Again, check the RPO codes on your door to see if you've got the one for traction control. If you don't, there is nothing you can do to "get" traction control, other than selling your car and buying one with it.
Boss002
Jul 24, 2015 10:47 AM
Javi Fierros
Jun 10, 2015 03:35 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
brentasan
Jul 7, 2002 08:59 PM
Jay-mak
Jun 14, 2002 05:40 PM
