Service engline light is on, reader said auxiliary emissions, what does that mean
Old Sep 11, 2004 | 06:54 PM
0toinsanein5.4sec's Avatar
the guy at autozone said it was to tighten the gas cap but that want it.
Whats the problem?
thanks
Old Sep 11, 2004 | 10:14 PM
HBHRacing's Avatar
Re: Service engline light is on, reader said auxiliary emissions, what does that mean
we would need an actual code number to help.. but.. autozone can not scan a 95
Old Sep 12, 2004 | 10:35 AM
they scanner they had seemed to work.
p1441 and p1442 i believe were te code numbers, they both said pretty much the same thing
Old Sep 12, 2004 | 05:22 PM
tdaddyz's Avatar
harlan, since he has a 3.8 95 he has the obdII so the scanner should work.
Old Sep 13, 2004 | 12:23 AM
weak95bird's Avatar
check the evap canister (charcol canister should be on the drivers side right on the other side of the gas cap) make sure all the lines are tight and not leaking, do you smell any fuel when you drive? basically all it is seeing is that the fuel is not as pressurized as it was, meaning a leak, lose fuel cap etc..
Old Sep 13, 2004 | 09:01 AM
HBHRacing's Avatar
it's either an early 96 or a cali car.
anywho.
I would bet that you have a borken vacuum line at the canister purge selinoid. thats the selinoid that has the line from the canister to it and then a line to the intake. Check the lines very well
Old Sep 13, 2004 | 12:59 PM
how would i get to that?
anywho.
its a cali car, i just drove it across country to college.
also around in the car would i find that? engine compartment?
thanks
Old Sep 13, 2004 | 01:55 PM
HBHRacing's Avatar
yes. it will be atched to the motor. I can not tell you specificly. you will see a selinoid. with 2 vac lines at it and a 2 wire connector. one line going to intake and another going to the canister. Follow the lines and make sure that they are intact
Old Sep 13, 2004 | 04:49 PM
ok thanks
Old Sep 14, 2004 | 02:10 PM
Nevermind i figured out what you meant, i can be retarted at times
Old Sep 14, 2004 | 02:56 PM
ok its the gas cap, i could hear a slight leak from that when i had the door open and the engine was on. the rubber part has cracks in it. i guess a new gas cap should probably fix the problem
Klypto
Mar 23, 2016 09:05 AM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
squarehead
Jan 15, 2015 07:02 PM
Dec 1, 2014 08:08 AM
mspennyhughes
Nov 28, 2014 03:22 PM
