Is replacing a fuel filter easy?
Old Mar 11, 2004 | 03:48 PM
Flare65's Avatar
From: Welcome to Chicago. Get out while you are still alive.
I had my car in at the dealer today for some last minute maintenace before the warrenty expires next month (had a wheel bearing that needed to be replaced).
The dealer said that I'm getting close to the 30K mark and that I should have the fuel filter replaced.
My questions are/is when should this be done? Is it easy to do? I was quoted $48.00 for it installed.
I've replaced the fuel filter on my '65 Mustang a few years ago. it wasn't hard at all with it being on top of the engine.
Any comments on this? Where is the fuel filter on my car? <--haven't spent much time under the hood.
My car is an '01 3800 car with a manual five-speed.
Old Mar 11, 2004 | 05:37 PM
ImportKILLER's Avatar
Be ready for a shower.
Underneath the rear of the car...driver's side. Small little cylinder-ish canister.
You can try to relieve some pressure by undoing your gas cap.
Old Mar 11, 2004 | 08:22 PM
dbzmatrix's Avatar
i changed the filter on my car, wasn't too bad. do like importkiller said and undo your gas cap a little while before you plan on changing it to relieve the pressure. i didnt get too much fuel spill at all, it was pretty simple. if you search for "f-fbody fuel filter install" on google or something there is a guide that shows you how to do it if you're still unsure about it.
Old Mar 12, 2004 | 10:08 AM
BradleyPeart's Avatar
I did that for the first time 2 weeks ago. It was really easy. If I can do it, you can do it. Follow, Shoebox's guide.
Save your money, do it yourself.
Old Mar 12, 2004 | 01:50 PM
nikkev's Avatar
www.installuniversity.com
There is a write-up there under "install documents"
PCLZ28
Dec 24, 2015 05:19 PM
Scottyboy
Feb 11, 2015 10:28 PM
Alex Barnes
Jan 24, 2015 10:21 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
