question about sparkplugs
Old Sep 17, 2002 | 10:45 PM
MeaN-GreEn-3.4's Avatar
I was told that u should change ur spark plugs every 100,000 miles, would it make a power difference if i got some splitfires or jus stick with the cheaper ones?
Old Sep 17, 2002 | 11:37 PM
NeoPaladin's Avatar
I strongly suggest changing your plugs at least every 100,000 miles. Preferably even sooner.
Anyway, I've heard nothing but bad things about the Splitfire plugs.
I switched to AC Delco Rapidfire plugs, and have found them to be even better than the Bosch 4+'s that I was previously running.
I believe that they're something like $3.00 ish per plug.
Well worth it.
Old Sep 18, 2002 | 12:45 AM
All_InTheRED's Avatar
100,000 miles??? Not on a 3.4!!!
Even on the ones made for the 100,000 mile tune-ups, try getting them out of an aluminum head.......they are welded to the head!
Spark plugs aren't that expensive......30K to 45K is about right, platinums maybe 60k miles.
I have the Rapidfires now.......swapped them in at 30K, 65K now....not one complaint.
Old Sep 18, 2002 | 12:58 AM
MysticTeal 95 V6's Avatar
I too have the RapidFires... swapped them into the car last spring. I changed out my plug/wires again recently and kept with the RapidFires. They were 3.14$ each for me from Advance Auto. I was lazy about swapping out my plug wires for some reason. I remembered today that I hadn't changed out the drivers side yet. Took me less than 5 minutes to pull/replace all 3 on the drivers side... if only the passenger side was the same Stupid EGR junk.
Old Sep 18, 2002 | 01:53 AM
PitySister's Avatar
i put splitfires' in my saturn back when i had that.....i started getting some very nasty hesitation probs, so i took it too mechanic....all the porcelain was cracked on every single plug....he says.....don't use splitfire....they suck....i agree
Old Sep 18, 2002 | 02:12 AM
MustangEater82's Avatar
I used splitfires, then when I fried 2 wires due to an EGR leak I replaced the plugs at the same tiem with rapidfires, they were 10 times better then the splitfires were even brand new.
Old Sep 18, 2002 | 10:53 AM
fbird95's Avatar
change the plugs every 30,000. Thats what i do. I'd stay with the stock plugs. I went to bosch platnum wires. They lasted a 2 weeks before serious hesitation occured. Went back to stock wires, and now is all good.
Old Sep 18, 2002 | 12:33 PM
94Camaro6cyl's Avatar
I am with them bro...every 30,000k....After 70,000k the factory ones were still in and were fried...DEF change every 30,000...
Lt4Z2897
Mar 26, 2015 03:02 PM
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
