Oil Pressure
Oil Pressure
I just picked up a 94 camaro with a 3.4 and after the engine gets warm the oil pressure only puts out about 10 psi. The needle is hanging just above the redline. Is this normal for a car with 126,xxx miles on it? What kind of oil pressures do you guys have?
If you gauge reads off, I wouldn't worry about it. Odds are it is a sensor...check everything out though. If everything is OK, don't worry about it.
I try to stay away from heavier oils unless there is a real good reason to.
Here is what to try: Use 20w - 50 oil if the pressure goes up, then your oil pump is weak and needs to be replaced. another way to tell is let the car come up to normal operating temp then listen to the motor with the hood up for the rods to knock, that also will tell you if the oil pump is going bad. either way low oil pressure is not good, it could cause you to spin or score a bearing and you will have to rebuild. hope this helps
-William
-William
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
