idel problems
Old Aug 25, 2002 | 12:23 PM
Zomie's Avatar
Post idel problems
Well, my car when it sits still idels from 450 rpm - 1500 rpm's and when its driving the power just seems to cut out and it dogs and accelerates slowly.
I added in some fuel treatment for fixing bad idel no help, I also added some fuel injecter cleaner, and added dry gas
None help!
95 Camaro 3.4L M5,
-Flowmaster muffler 80 series with quad tips,
-White Racing Stripes
-LeBra front end cover,
-Interior purple neons
-2000 Trans Am rims
-Car audio
180 Watt Kenwood head unit
jbl's all around
3 10" Jensen 375 watt subs with a 250 watt amp and a 500 watt amp(I know its cheap but I really don't want to kill any little old ladies)
http://members.glis.net/zomie
Old Aug 25, 2002 | 02:09 PM
Thraxz's Avatar
Post
450rpm is really low for a v-6 especially 3.4l. I assume its an auto. It sounds liek ignition to me. Your gonna hafta check your coils, wires and plugs. Thats seems to be the biggest problem with the 4th-gen camaros, keeping the ignition maintained. So checkk all of that crap and get back to us. otherwise it could be the air filter... sensors... the list goes and goes.
Old Aug 25, 2002 | 02:35 PM
All_InTheRED's Avatar
Post
I take it........no codes????
Max
'95 Camaro V6..BB Triflo quad-tip catback, 180 degree Themostat, WaterWetter, K&N Air Filter, AC Delco Rapidfire Spark plugs, TB-Bypass, BMR Chrome-Moly STB, Front & Rear 1LE Sway Bars, 255/50/16 Eagle GS-C & F1 Steel, Dark Tinted Windows. Fog-lights on when Hi-Beam On Mod done tooooo.
www.home.earthlink.net/~airspeedy2
'99.5 F-250 SuperDuty CrewCab,PowerStroke Diesel, 2wd, Torreador Red, TS Extreme Chip & LPG, BTS Tranny & Converter, Maddog Stage 2 Injectors, TTS "Hybrid" Turbo (35psi max. boost), Detroit Locker ......14.2@99mph. 436rwhp/869ft.lbs.
...lets just say its not stock.....well DUH!
Old Aug 25, 2002 | 03:28 PM
Zomie's Avatar
Post
I just put in new plugs today, the wires are fine the coils have 10K on them!
I am starting to think its a Mass air flow senser! Stupid things are expensive too.
Its a manual like my sig says.
I am tempted to put an ad in the paper for 5K and getting rid of it, and buy a ford or a geo!
Old Aug 25, 2002 | 03:43 PM
Post
Hate to pop your bubble
But our 3.4's don't have Mass Air Flow sensor's, they use speed density to calculate engine load, using a MAP sensor.
Max
Old Aug 25, 2002 | 04:28 PM
Zomie's Avatar
Post
Thats what I ment, the stupid senser that measures the incoming air.
Old Aug 25, 2002 | 06:33 PM
Post
.....I think your on the right track.
Max
Old Aug 25, 2002 | 11:44 PM
Davio6000's Avatar
Post
your in the same boat im in. my drops to about 600 then right up to 2000 rpms, up and down by itself. i found out the problem once i hooked it up a computer. heres the problem its the ecm, you need to bring you car to a dealership for a new one. a big bummer.
Old Aug 26, 2002 | 11:15 AM
Zomie's Avatar
Post
The ecm is the computer correct, thats like $500!
Fh:SLKHDF:SLKHDF:LKSHDFkldhsfakhd
worthless chevy!
Old Aug 26, 2002 | 04:58 PM
camaros_4_lfe's Avatar
Post
worthless chevy whats ur problem it might not be that and if it is buy one at a salvage yard all things break on all cars just fords and imports the most
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
