how do i know where to cut the access door for my fuel pump
Old Apr 12, 2010 | 02:13 PM
redz28camaro's Avatar
Question how do i know where to cut the access door for my fuel pump
i have a 97 z28 camaro 5.7l.. i know my gas tank is right behind my back seat but not sure where the fuel pump is located..? and what tool should i use to cut into it?
Old Apr 14, 2010 | 09:36 PM
95camaroinok's Avatar
Try a search in fuel and ignition https://www.camaroz28.com/forums/fuel-ignition-74/
Old Apr 15, 2010 | 03:58 PM
rsm93z28's Avatar
...and here, too...
http://taekwondoplus.org/z28/fuelpump.html
Please pay very close attention to the possibility of a fire hazard from employing spinning, grinding or electrically driven metal cutting shears... even pneumatic tools can spin abrasive wheels fast enough to stream sparks if you decide on being too impatient to take your time doing this and wind up working in a manner to" speed things up". Instead, use the safe methods of cautious cutting and do this job out of doors... away from structures, loved ones and strangers. Keeping a Large ABC Fire Extinguisher handy for close encounters with a fire is a good idea, too.
Old Apr 15, 2010 | 09:23 PM
right on dude. that linked help alot.. thank you
Old Apr 19, 2010 | 11:47 AM
shaysbadboy's Avatar
I did the same thing when i had my 85 camaro alot easier than dropping the whole rearend, I used a hammer and a really sharp chisel, no risk of sparks just lightly tap it, if your chisels sharp enough it will cut through pretty easily.
cmyname1
Feb 19, 2015 08:38 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
ANDYZ28
Dec 29, 2014 09:13 PM
