Fuel pump
Old Apr 27, 2003 | 06:00 PM
kennyrebbe's Avatar
Fuel pump
I just did the v6-v8lt1 swap in my 95 camaro. I was wondering if the stock v6 fuel pump would be able to feed the lt1 with no problem, untill I get a new pump. Or even if I need to get a new fuel pump. I don't know. What do you guys think. Thanks.
Old Apr 28, 2003 | 10:28 AM
kahouna23's Avatar
I remember someone on here that did a LS1 swap and ran the stock V-6 fuel pump. I think he eventually swapped it out because the volume of fuel required to run the LS1 is much more than the V-6 pump can put out. As for "temporarily" running a V-6 pump......that's a little iffy. I wouldn't run it very long, could cause other problems.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
